Suspension Anyone got Bilstein Shocks on their R56 yet?
#301
I don't know if NM Springs and HD's have the same issue that I have had with the TSW springs and HD's, but the front rides higher than the rear. I have said this before as well, but if I had a redo, I would have skipped the lowering springs and just gone for the HD's for better ride quality. if lowering is your goal, spend the extra money for the sports. Why risk it? Installation isn't easy or cheap, so do it right the first time.
TREX
TREX
#302
So after running with the Bilstein HDs and the summer wheels and tires back on, I have to say that I am completely satisfied with the new setup.
If you are looking for a better ride and better handling without lowering your R56 MINI, the Bilstein HDs are for you. You will not be disappointed!
#303
Im installing the bilstein sports with H&R springs this weekend on my Clubman S with 27,000 miles on it. Can anyone reccomend what other peices/mods are vital for me to be using also such as bushings, links, etc. Will my camber be affected enough that i need to adjust it via control arms amber plates? any help is appreciated thanks.
#304
Just installed the bilstein sport H&R combo and the ride is phenominal. I finally feel like im riding in a sports car, ride is firm but doesnt feel like im bouncing all over the place as with stock. the front does seem to be a little higher than the rear im hoping they will settle soon. None the less i would reccomend this to anyone that doesnt quite need the capabilities of coilovers.
#305
#306
930 Engineering (02-27-2021)
#307
#309
#310
I was looking through their site & they list the sport shocks for $538 shipped, but I didn't see any HD's
according to the faq the sport models are meant to work with lowering springs.
I'd love to hear some feedback from anyone running these, I'm debating between these & the Koni FSD's.
#311
Having run the FSDs I would say these and the Bilstein sports are aimed at different applications. The FSDs are aimed at a user wanting great road ride and good control on the road; a big step up from stock. However, I did not find them good for track or autocross. The Bilsteins are aim at the track and autocross user. The road ride will probably be stiff but well controlled (have not yet tried the set I have). The Bilsteins can be used with lowering springs whereas the FSDs can not; both can be used with stock springs. Hope this helps.
#312
I have installed the Bilstein / Eibach B12 kit on my 2012 MCS with 70k miles and can report the following:
As advertised, it does lower the height about 1 inch all around
The alignment can be corrected to original specs without any additional parts, adjustable links were not needed.
If you install them yourself, start with the rears to build confidence, you'll need it for the fronts! I didn't do this and the first front took me about 4 hours; the second about 45 mins, 30 each for the rears.
Not going to post another set of instructions, but on my car it was not necessary to disconnect the steering knuckle, just wiggle the parts around and the strut will come out, really.
Overall, a very worthwhile project and upgrade, handling is much improved, slightly stiffer than stock except on small stutter bumps, where it seems softer. The disturbing tendency of the stock suspension to skitter across these in a corner, even without the horrible OEM runflats is gone. The difference is amazing.
#314
#315
interesting - 56mm bumpstops are ~2.2 inches, and my mini's weight is 752 & 784 in the front driver's and passenger's respectively. I don't know what the jcw spring rates are but I've got to be riding on the bumpstops no? what are you setting yours at?
#316
My assessment of the B8s - they are fantastic
Going by memory (the MINI shocks were pretty shot when I replaced them) the B8s are about as stiff up front and a bit stiffer in the rear than MINI's optional sports suspension shocks. The huge difference is what I would call "control". The jitteriness of the MINI shocks is gone and even though they are overall stiffer the ride is hugely improved, to the point the RFTs are tolerable.
On the track, B8s are a vast improvement over the MINI sports suspension and much better than the FSDs. They are a great option if you are not looking for an adjustable shock.
#318
I have them and love them. This is a completely different car with the B14 setup. I swear it rides better and the handling is incredible.
#319
#320
Bilstein is the OEM supplier for our cars. So i would expect them to be the same shocks that came on the car. B4 is direct oem replacement parts. B6 and up is monotube with different valving.
#321
I used the Bilstein B4 struts on my MCS with out sport suspension, but I got the Bilsteins that were listed for the sport suspension (different part numbers). The ride is lees harsh than the Delphi that came stock. No more crashing into expansion joints and railroad tracks fearing my car would break something. On my favorite off ramps I can still hit the same speed. The car just feels more in control. Still debating if the B6's would have been better, but I could get these sooner.
#322
I am going to take my oem Sport Suspension springs and put B6's on them so I have oem ride height but with a shock that really works :-)
#323
I bet they are the Bilstien for the Sport Suspension, but check. I had Sport Suspension and finally gave up on Koni shocks and went to Swift Lowering Springs (Spec-R's) with Bilstien B-8's and boy of boy does it handle!! Rides great with zero complaints about ride even after 25K miles.
#324
If it helps at all, I am running the Sports suspension springs with the Bilstein B8s. If I had known how much better the B8s are over the Sports suspension shocks, I would have replaced them on the day I picked up the car. They are good enough that have put the OEM Continental RFT tires back on it for DD. Overall, I would say that the B8s are well matched to the stiffness of those springs. The B8s might be a good alternative to the B6s for you, especially considering you already seem to like them. Just a thought.
The FSD's felt good, when they worked but they failed within a month each set.
#325
Now I am not sure which I have, but I was told they were the "Bilstein sport shock" . I bought them used and they were off an autoX car so I assumed they were B8s.
The Bilstein web page, as you said, lists the B8s for lowered cars, but it also says that they are "sport tuned" whereas that was not in the description for the B6. Wonder what that means? However, they seem to be working well with the springs and I am liking them.
Sorry to here about issues with the FSDs. I have a set waiting to go in our base MINI.
