Suspension Should I replace my rear trailing arm bushings on my 131K MINI Cooper
Old Jun 26, 2008 | 07:56 AM
Chilipeppa03's Avatar
Chilipeppa03
Hey guys, I have a 2003 MINI Cooper with about 131,000 hard miles! I have had mostly all the suspension re-done, but I have not had the rear trailing arm bushings replaced. At this high of mileage is it about time to replace them? What are some of the signs of them being worn out? I am considering the Powerflex rear trailing arm bushing inserts
http://www.outmotoring.com/mini-coop...shing_kit.html
What are the good and bad about the insterts? Or should I just have both of the rear trailing arm bushings replaced (stock)?
Old Jun 26, 2008 | 05:05 PM
Chilipeppa03
Any thoughts?
Old Jun 27, 2008 | 07:49 AM
k-huevo's Avatar
k-huevo
The photo shown in the Outmotoring link is a steering rack poly bushing not a trailing arm insert.
Verify the trailing arm build version before purchasing a poly part:
Early model bushing mount
Late model trailing arm
Yes, it is a good idea to replace the trailing arm bushing on a high mileage MINI. My early build had begun to crack/rot at the 60k mark.
For the early build, the entire bracket needs replacement, because OEM bushings alone are not offered; it’s not a difficult task. New rubber always feels good. An alignment will be necessary after replacing trailing arm brackets.
I tried the inserts on my early build.
The effect was much like adding a very stiff sway bar, less body roll and pitch, plus the changes were fun in the beginning. After a few hundred miles I found the limited arm articulation to be undesirable (I felt like a bobble head) and couldn't wait to take them off. Having tried poly in a variety of suspension applications I prefer OEM rubber by far. My recommendation is to replace the bracket & bushing with OEM parts.
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
Aug 7, 2015 05:56 AM
