Suspension JCW @ Track Day Willows Springs Raceway
Old Jul 18, 2003 | 01:36 PM
  #26
Strad's Avatar
Strad
Which Sparco belts are those, the 4 point snap in?
I've been looking for something more affordable than the Schroth harness @ $225.
Do the Sparco work well?
thanks.......
Old Jul 18, 2003 | 04:05 PM
  #27
jlm's Avatar
jlm
rts:
that "pillow block" contains a thrust rated, sealed, double row angular contact ball bearing to handle the steering action and transfer the load force from the strut shaft to the chassis. The bearing is mounted in the external 3" dia cup fuly suspended in cast-in-place polyurethane to provide some cushion and alignablity. I made the unit as thick as it is to match the stock non-adjustable rubber mount, since I felt using the camber plates should be distinct from trying to lower the car.
I was not able to source a spherical bearing that would accomodate rotation and alignability for a reasonable price (I pay about $20 for the angular contact bearing...the closest spherical bearing was about $75. I may yet review that option however.
Old Jul 21, 2003 | 11:25 AM
  #28
M7's Avatar
M7
RTS:
Glad you had a fantastic weekend at Willow.....but we are all waiting for those lap times with and without the JCW kit!
Indulge us please..
Old Jul 21, 2003 | 11:38 AM
  #29
Casey's Avatar
Casey
Well Sparco's aren't really going to be much cheaper and they will require the use of a rollcage to mount them which if you already have one or are getting on it isn't bad..but otherwise the 225 for the schroth's is a lot cheaper.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Mini'mon
Aug 16, 2015 04:15 PM
M7Speed
Aug 13, 2015 07:08 AM
ki7hy
Aug 12, 2015 07:07 PM
