Vibration when travelling from 2k to 3k RPM
Old Apr 15, 2007 | 04:00 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
I have a 03' MCcvt. Last night I was coming home on a major road and was cruising along around 50-60mph. As I would go from 2k to 3k RPM I got a pretty strong vibration in the wheel, pedals, and felt like my seat. When both accelerating and decelerating. This is the 1st time that I've felt this, any ideas what may be causing it, or if its actually normal?
Old Apr 16, 2007 | 08:45 AM
Rastven's Avatar
Rastven
Changed rims/tires recently?
Old Apr 16, 2007 | 08:47 AM
Guest's Avatar
Guest
If it's only at a certain RPM i'd go with a busted engine mount.
If it's speed relative you may want to check your tire balance.
Old Apr 16, 2007 | 04:48 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Nope, been on my rims since day 1, and this set of tires since November.
Hmm, would I be able to see the engine mounts from just popping the bonnet, and if so, what am I looking for?
Old Apr 16, 2007 | 05:03 PM
erickvonzipper's Avatar
erickvonzipper
You're looking for (black) fluid leaking from this unit:
That's the front engine mount damper, notorious for leakage. Look below the car, as well, for this black stuff on the inside of the wheel and/or on the ground. My car has already had the OEM damper replaced. That's one of the reasons for the aftermarket damper above it.
Zip
Old Apr 16, 2007 | 06:09 PM
justaguyinvegas's Avatar
justaguyinvegas
Ummm...your picture sure looks like the 05-06 mount......the 03 is different.
Old Apr 17, 2007 | 02:55 PM
erickvonzipper
Yes, you are right. The 03 is a rubber-type mount and not that metal cylinder looking thing. Sorry.
Zip
Old Apr 18, 2007 | 02:57 PM
joey1320's Avatar
joey1320
check your front wheel bearings. had a similar problem on a customers car last friday, turned out to be the right front wheel bearing. kind of weird since it wasn't constant or always present. it would come and go after you got over 55mph.
Old Apr 18, 2007 | 03:30 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Well, i popped the bonnet, there wasn't any juices flowing around. The vibration seems to have went away, so I guess if it comes back I'll have to take it in.
minieater
Oct 28, 2015 02:15 PM
Fourflys
43
Oct 20, 2015 09:42 AM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Suspension Products
Sep 10, 2015 11:46 AM
