North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   The clock lights up but doesn't display any numbers (https://www.northamericanmotoring.com/forums/stock-problems-issues/98012-the-clock-lights-up-but-doesnt-display-any-numbers.html)
Hansii Apr 13, 2007 09:19 AM
Like the title says, the clock above the rearview mirror lights up, but doesn't display anything. I suspect this might have happened when the car was in for a power steering pump replacement, but I recently bought the car and I am not 100% sure it worked when I bought the car, so it might be totally random.
I tried searching around, but didn't find much help.
Foxtrot_Xray Apr 13, 2007 11:57 AM
It's a simple replacement/removal. I'd remove it, take it apart, and reseat the LCD screen in it. (Assuming you've checked all fuses, etc. Obviously, the clock has to get power to keep the time and such.)
Hansii Apr 13, 2007 12:21 PM
I figured it had power since the background light works, is there a seperate fuse only for the clock?
I will probably have a go at reseating the lcd then, is it hard to take it apart?
1caliente Apr 13, 2007 03:37 PM
Here's something to consider, and easy to check. I have a 2005 MCS and my clock would read -- -- and my trip counter would read zero. Every so often there was a hesitation when I started and every thing reset. Turned out to be a loose battery cable. Make sure they are good and tight, and you may solve your problem.
Hansii Apr 21, 2007 10:46 AM
I tried to take apart the clock yesterday, I tried to just pull the lid off, but I didn't want to use too much force. What is the best way to take it apart?
And I have another small off topic question, how do I take apart the key in order to switch ou the battery?
PACSman Aug 10, 2011 09:17 PM
Resurrecting an old thread. I have the same issue. How do I remove the clock from the headliner.
