Warranty vs Modifications
Old 01-26-2007, 11:03 PM
ChrisO's Avatar
ChrisO
ChrisO is offline
I was unable to find a thread that addressed this issue and I expect this has been discussed many times, so forgive me, but . . .
I am looking to add a Alto CAI, 15% pulley & H-Sport sway bar.
Do any of these modifications void or affect the warranty on my '04 MCS?
ChrisO
Old 01-27-2007, 04:22 AM
Febmoon1's Avatar
Febmoon1
Febmoon1 is offline
They all could void it depending on the dealer. But with that said the pulley is most likely to void a warranty.
Old 01-27-2007, 05:52 AM
tdm156's Avatar
tdm156
tdm156 is offline
Ruling the curves
I have heard the same thing that pulley would almost definately void the warranty but I would check with your MA/SA at your dealer and find out what they would consider mods to void warranty. Good luck and Happy Motoring!
Old 01-27-2007, 07:14 PM
apexer's Avatar
apexer
apexer is offline
Some dealers are more mod friendly than others. The CAI and H-Sport bar shouldn't be much of a warranty problem. Actually, neither should the 15% SC Pulley although some dealers see it as a warranty buster. See what your dearler has to say... get it in writing if possible.
Old 01-27-2007, 07:26 PM
ScottRiqui's Avatar
ScottRiqui
ScottRiqui is offline
In general, the dealer will only deny warranty coverage for problems that are caused by your modifications. So, if you install the pulley, intake and swaybar, and your radio later stops working, that would probably be covered.
But if you start getting noises from your rear suspension after installing the swaybar, you might have a hard time convincing the dealer that the swaybar isn't the culprit.
Old 01-30-2007, 01:10 PM
Bigcoyote's Avatar
Bigcoyote
Bigcoyote is offline
Yea!! what he said ---
It is up to the dealer - if you put on the pulley and a week later your supercharger freezes up - you are going to have pay for it - they will blame the pulley.
But if the failure is not related to any non-factory parts then you should be ok. Just be prepared to argue with the advisor and manager if you have to.
Good luck
Old 01-30-2007, 02:55 PM
jaynicholson's Avatar
jaynicholson
jaynicholson is offline
You need to ask the service manager at your dealership before you start doing mods. Generally, if you're up front with them they will tell you what mods they are comfortable with. This is what I did and I've yet to have an issue.
vulkandino
10-31-2015 08:29 PM
schr5530
10-01-2015 05:11 PM
Suspension Products
10-01-2015 11:53 AM
point665
09-29-2015 12:41 PM
Emnotek
09-29-2015 07:37 AM
Quick Reply: Warranty vs Modifications
