Is the motor mount oil filled?
Old Oct 27, 2005 | 02:54 PM
mmatarella's Avatar
mmatarella
I've got a oil leak on the passenger side just inboard the wheel. Under the hood the only oil visible is all around the engine mount. There's a canister that rests on the frame, and on top of that canister is bolted the engine mount. I'm assuming that canister is some kind of damper?
All the oil is heaviest at the base of that canister though it's also run for and aft. It sure looks like thats the source, I don't see any oil elsewhere...
Old Oct 27, 2005 | 02:57 PM
PurplePeopleEater's Avatar
PurplePeopleEater
I don't know anything about oil in the motor mounts (thought they were just rubber) but my "mystery" leak turned out to be a bad gasket on the oil filter canister.
Old Oct 27, 2005 | 03:04 PM
shooler's Avatar
shooler
The engine mounts are oil filled (at least on the 05's). My Mini had the same leak and the dealer replaced the mount. Time to make an apppointment...
Old Oct 27, 2005 | 03:11 PM
mmatarella's Avatar
mmatarella
Thanks.
I'm a '05 and suspected that was the case...
Old Oct 27, 2005 | 04:22 PM
flav's Avatar
flav
i have the same thing. dealer told me it was nothing. so they refuse to fix it. oil is leaking right from the bottom of the mount on the passengers side. so what will happen to my car if it never gets fixed. because it looks as if the dealer is not acknologing the problem. please help!!!
Old Oct 27, 2005 | 04:23 PM
flav's Avatar
flav
can you post a picture please. what am i to do now???
Old Oct 27, 2005 | 06:43 PM
shooler's Avatar
shooler
The dealer has to fix it. It is def a warranty issue. I first noticed a small pool of oil on my garage floor from the mount leaking and it got progressively worse. I can't imagine a dealer telling you this is normal.
Old Oct 27, 2005 | 07:12 PM
flav's Avatar
flav
if the insist thats not what it is then they dont have to fix it.
one day i noticed a pool of oil around my passengers side engine mount. dry oil. and took it to my dealer and they said that it was not oil but some fluids that must have splashed there during the last maintenence. but believe me it looks like oil and it is a pretty large amount of it coming right from the engine mount. what is going to happen if it is the engine mount oil and i dont get it fixed??????? and is this an expensive fix. i cant think of any reason the dealer would lie about it. they have fixed other issues with my car without any problems. so in other words is it really bad for my car not to get it taken care of if it is the engine mount?
Old Oct 27, 2005 | 07:34 PM
shooler's Avatar
shooler
When I contacted Rasumussen Mini (local Mini dealer in Ptld, Or), the service advisor was aware of the problem. Have your dealer call Rasmussen Mini and ask for Ann Fry. They have record of a few motor mounts with this problem. As for what may happen, the mount uses the fluid to dampen shock/vibration from the engine. If all the fluid leaked out, the mount would no longer work as designed, but I'm not sure of the detrimental effects to the car. You have a warranty-use it.
Old Oct 27, 2005 | 09:28 PM
flav's Avatar
flav
here are pictures of my leak. or so called leak. and remember the dealer says this is absolutely nothing at all. what do you guys think. and how about you guys that had an actual engine mount leak. did it look like this.
Attached Thumbnails Is the motor mount oil filled?-dscf0133.jpg   Is the motor mount oil filled?-dscf0135.jpg   Is the motor mount oil filled?-dscf0136.jpg
Old Oct 28, 2005 | 06:07 AM
mmatarella's Avatar
mmatarella
Yup.
Mine is the same way except all nice and wet with fresh oil. I can also see the oil pulsing around the base of the damper when the engine is running (from the vibration).
Will take pictures today when I get home if it isn't all dried up and looking the same by then. I noted only a few more drops of oil this a.m. Don't know if it all leaked out now or if a fresh batch will leak after running the engine.
Old Oct 28, 2005 | 08:32 AM
flav's Avatar
flav
i feel like it is the oil filled engine mount too. but i showed the dealer and the mini tech (pointed right at it) and they said it was just extra fluids from previous maintenence, and was unrelated to anything going bad in the car. the dealer has been very good to me. fixing and replacing anything that has gone wrong with my car over and above normal service. thats why im so confused. i mean this looks terrible. but they say it is nothing. what do i do. if i take it in again they wont do anything about it. and im not a mechanic so i cant prove anything is wrong with the car. i dont want to call mini usa because my dealer has been so great to me and im not looking to get them in trouble. i just dont want my car to go unrepaired especially after warrenty. please help.
weird thing was the mini tech sprayed some engine cleaner on the stain and it did not wipe off (or at least not very easily). he said "see, oil would have wiped right off". well then what is it.
Old Oct 28, 2005 | 09:23 AM
CoryB
They say it's normal? Have them show you the same thing on other customer/new MCS's in the shop. If they don't ALL have the same leakage, point out that they need to fix those without the leak as they're abnormal.
Old Oct 28, 2005 | 10:00 AM
mmatarella's Avatar
mmatarella
Just got off the phone
...with Sterling. The SA there says there is no oil in the mount damper.
But then he's trying to convince me that's the oil filter! I guess words just don't describe it. As soon as I said oil leak he's thinking elsewhere.
Old Oct 28, 2005 | 10:21 AM
SCMCS's Avatar
SCMCS
Mine started to leak some kind of watery oily fluid. The leaking has stopped but I think this is because all of the fluid has leaked out. I don’t notice any difference in engine vibration or movement. My car is about 3000 miles from a service I will be reporting this problem then. Looks like a new issue that dealers don’t know about or don’t want to acknowledge for some reason say like crappy windshields.
Old Oct 28, 2005 | 10:36 AM
Jdewey's Avatar
Jdewey
motor mounts
There are several different kinds of motor mounts on MINI's. That looks like the liquid filled mount to me! There are mounts on some models/years that are nothing like that, and use rubber bushings.
I think your dealer is full of a dark substance...., but perhaps they are not familiar with the mount.
J. D.
Old Oct 29, 2005 | 11:55 AM
mmatarella's Avatar
mmatarella
Thanks Shooler...
I spoke with Ann yesterday after reading your note and she was very helpful!
Old Oct 30, 2005 | 07:50 AM
SCMCS's Avatar
SCMCS
So the 64,000 dollar question is- Are the motor mounts oil filled and if they are leaking should dealers know if this issue and replace them under warranty?
Old Oct 30, 2005 | 10:16 AM
shooler's Avatar
shooler
Glad to hear it Ann is great! We had a number of issues with our MCC and she was always very helpful.
Old Oct 30, 2005 | 10:19 AM
shooler's Avatar
shooler
SCMCS-The mounts ARE fluid filled (at least on the 05's). If they are leaking, they should be replaced.
Old Oct 30, 2005 | 10:29 AM
Ryephile's Avatar
Ryephile
eww that's gross. It makes me glad I have the old engine mount
Old Oct 30, 2005 | 05:25 PM
mmatarella's Avatar
mmatarella
Yup.
...And in today looking at some underhood photos taken of my car a couple weeks ago I can now see that it started as a small leak a while back. I hadn't noticed anything amiss as it was a small dirty area but now I realize there had been some leak already and dust and dirt was sticking in that area. I caught it purely be chance the one time the majority leaked out. Most folks would probably not have the luck to spot it, and I wonder how many are running around this way and don't know.
I spoke with the sales manager by chance today at a club event and mentioned it to him. He said he'd investigate and pass the word around that dealer too.
And yes, it was repalced under warranty...
DixonL2
Apr 13, 2021 08:05 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
Phantogram
Aug 12, 2015 12:11 PM
