North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   Dash won't turn off (https://www.northamericanmotoring.com/forums/stock-problems-issues/352135-dash-wont-turn-off.html)
jjcsnlynn Nov 7, 2020 04:45 PM
Dash won't turn off
Just trying to revive a 06 MCS that was bought with a blown motor. Some parts were removed from the interior. The engine has been replaced but the dash won't turn off with the key. In fact when the engine started, the key was removed and the engine stayed running. Had to pull the battery terminal to shut off the engine.
Any ideas where to start?
MVPeters Nov 7, 2020 05:32 PM
Start with some switch cleaner in the ignition switch.........
jjcsnlynn Nov 19, 2020 06:28 PM
We got the lights to tuen off by removing the BCM and reinstalling it.
now the scanner won’t connext to the DME.
only thing found is fuse 5 has no power
jjcsnlynn Nov 24, 2020 08:08 PM
Alright. Figured this out.
The engine is a 2005 engine and harness. Caused the dash lights to stay on, engine would only idle ( barely) and would not shut off when key was pulled out.
Installed a 2006 harness onto the engine and everything works as advertised.
who knew?
