North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   AC doesn't work - pressure seems good (https://www.northamericanmotoring.com/forums/stock-problems-issues/351748-ac-doesnt-work-pressure-seems-good.html)
BillyMac Oct 16, 2020 01:13 PM
Hi,
Mini 2005 Convertible base R52 and the AC doesn't seem to work. I thought it was the compressor because there was a noise when I turned on the AC. I loaned the AC gauges though and pressures on low and high side were the same when off, and when on, the high went up and low went down. I also noticed that outside of the car the AC doesn't make a noise. So I think the compressor is OK. It was a little low so I added a little bit to get it in line with the chart for the temp. But the AC still isn't blowing cold air. I cleaned out the air filter, and that frankly looked like a rodent had made a home in there at some point. It was a nest. So that's been cleaned out as well.
Here's a video of the noise that it makes when the AC is turned on. Is that the expansion valve by chance?
https://imgur.com/myDMkEI
Thanks!
