R56, 98k, Transmission seems to slip when engine is cold for first 5 minutes...and th
Old Aug 1, 2020 | 07:36 PM
mark941122's Avatar
mark941122
[size=13px]Mini: R56, Automatic, 98k original owner, Hardtop S[/size]
Issue: When I leave in the morning and driving down the street as the car tries to shift into gear it slips(?), it doesn't engage right away. It's scary as it revs past without engaging. This lasts for about 5 minutes. Also can happen whenever the car has been left unused for hours. Thus a cold engine.
Time: Started 2 years ago. Continues like clockwork every day. No change. No worse, no better
Other factors? Three years ago I had the transmission fluid flushed/changed...just because I thought that was something you do. I now know it wasn't really necessary. Anyways I went to another mechanic telling him this and he checked the fluid/level and said it was ok.
Also: If I warm up my car and let it idle for 5 mins in the garage it won't slip. Again, the cold engine seems key.
Fears: Transmission ruined/end of my Mini. Have had this fear for 2 years, but nothing has changed.
Help: Please
Old Aug 5, 2020 | 12:23 PM
Lancaster's Avatar
Lancaster
Sounds like maybe the wrong trans fluid was installed. Can you confirm it was the correct fluid?
Old Aug 7, 2020 | 07:35 PM
MiniToBe's Avatar
MiniToBe
The ATF needs to be topped up a bit more.
When the ATF heats up, it expands hence not slipping after it warms up. Sometimes mechanics don't know what they're doing!
uconnhuskiesfans
Jan 10, 2022 12:01 AM
mark941122
Jun 21, 2019 07:49 PM
Chazman
Feb 9, 2016 02:33 PM
orfordbrits
Dec 22, 2009 09:48 PM
mini_dreams
Feb 22, 2007 01:58 PM
