Power steering pump - how to manually activate? - Should it run in Ign-on?
Old Jun 25, 2020 | 07:43 AM
AndrewVanis's Avatar
AndrewVanis
1 - Power steering pump - how to manually activate?
2 - should it run in ign-on key position or just when motor is running?
I wish to flush the PO old fluid (Generic PS fluid) but don't want to start engine as I am in service mode plus my exhaust manifold and exhaust are off waiting on parts.
Being in ign-on and turning the wheel doesn't activate the pump.
Thank in advance - Andy
Old Jun 25, 2020 | 01:42 PM
ssoliman's Avatar
ssoliman
why are you trying to active the pump? don't need to do that to replace fluid as far as I know
Old Jun 25, 2020 | 02:03 PM
AndrewVanis
I'm looking to purge the prior (wrong) liquid.
Drained the reservoir, have the pump out hose (hose into the reservoir) going into a container and filled the reservoir with the correct fluid and wish to run the pump so it flushes (pushes) out the wrong liquid from the steering system after which I will reconnect the pump out hose back to the reservoir and fill to mark.
Old Jun 25, 2020 | 06:08 PM
Minifenrir's Avatar
Minifenrir
There is a perfectly good how-to right here in this forum. All it needed was a 2 second search.
https://www.northamericanmotoring.co...g-fluid-431168
Old Jun 25, 2020 | 06:17 PM
AndrewVanis
the important part of this reply: 2) I bet applying direct voltage to the pump should work. If anyone has done this I'd appreciate some guidance considering the PS seems to be a sensitive beast.
the rest of the reply: yeah, saw that a while ago - it is one of the things that had me go to the Method 2 listed there.
"The next step requires starting the engine and moving the steering wheel to circulate the power steering fluid"
Two things on that
1) guess running means running - too bad...Often Ign-on turns on all running functions
Saltysalt
14
Jan 28, 2016 10:44 AM
nelsonht
Jun 25, 2012 05:10 AM
jgLabrown
Nov 25, 2009 10:06 AM
jso123
48
Feb 20, 2009 02:43 PM
2002redMCS
Nov 12, 2007 08:00 AM
