Emergency Brake
So I'm having an issue, I replaced my back calipers, rotors and pads. Found out that my left e brake cable was bad so I left it off of the caliper. But my right Cable seems fine but I do not have a e brake now, it's not engaging it moves up and down fine connected to the cable. Any help would be very appreciated. I'm at a loss
I believe that the parking (emergency) brake cable is a loop that runs from one side, around the handle, and back to the other side, so if you disconnect one side you have no braking on the other.
Yep, its on that pivot mount: that has to have both cable s in place,
https://www.northamericanmotoring.co...in-an-r53.html https://www.northamericanmotoring.co...r-caliper.html https://www.northamericanmotoring.co...ke-freeze.html https://www.northamericanmotoring.co...ini-cables.jpg |
