North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   Driver's side axle seems stuck (https://www.northamericanmotoring.com/forums/stock-problems-issues/335459-drivers-side-axle-seems-stuck.html)
89325iturbo1 Jan 25, 2019 10:08 AM
Any tips on getting the axle out of the trans? Put a pry bar behind to try to pop it out.
Yes it's out of the spindle side . With the passenger side out anyway to tap on the driver's axle through the trans?
JAB 67 Jan 25, 2019 11:13 AM
I would NOT recommend trying to tap 'through' the transmission. The first time I removed the driver's side axle I was briefly stumped, but it eventually came out. I used a carpenter's pry bar; you want to get something as far in as possible. The axle is being held in place by a circle on the splined shaft that enters the transmission. Just a friction fit. It will come out eventually.
AoxoMoxoA Jan 25, 2019 12:12 PM
Mod MINI's video on a clutch replacement shows the "popping out" method for the driver side axle at 22:43 of this video:
89325iturbo1 Jan 25, 2019 01:05 PM
I had a pry bar on it. But will give another try, I know it just snaps in. Maybe I just don't have it deep enough behind. I didn't want to damage the seal on the trans to much.
thanks for the video as well . Kinda what I was trying to do.
AoxoMoxoA Jan 25, 2019 01:37 PM
Originally Posted by 89325iturbo1 (Post 4446472)
...I didn't want to damage the seal on the trans to much.
The seals aren’t too much money. Not a bad idea to replace them if axle is out. They probably have more than a few miles on them.
FYI:
Driver’s side & passenger side seals are separate part #s.
Tgriffithjr Jan 25, 2019 08:16 PM
Try rotating it back and forth motion while popping.
89325iturbo1 Jan 26, 2019 01:55 PM
Got it out, combination of moving with hands and pushing on prybar with my foot.
Tgriffithjr Jan 26, 2019 04:47 PM
Good deal! When you first try it you think you’re going to break it, but they just get stuck.
A383Wing Jan 26, 2019 09:20 PM
I used a 1" diameter brass drift and a hammer on my car when I had to pull the axles
Bryan
