2011 MC S Wont Start After New Battery
All --
I have a 2011 MC S that I just purchased. Original battery was in the car, wife left the lights on and you know the rest. The car would not start so I took the battery in to have it checked / charged and they said it was fine (though the voltage was up at 15.6 volts). Tried to start again and nothing. I put a new battery in and still nothing -- the starter does not engage and the engine does not try to turn over. I just get a ticking noise. My Ancel AD310 shows P10F6 -- "Control Phase with Circuit Opened." Any thoughts? Is it possible that this is part of the electronic immobilizer system? Maybe a bad battery in the key? HELP!
Thanks!
Thanks!
Hello There,
You may have something else, other than battery related, going on.
FYI - Mini has a protection feature that automatically turns off headlights if left on to preserve battery. So, it highly unlikely that accidentally leaving headlight switch "on" killed the battery.
Good luck,
W
Good luck,
W
I just created a thread on the CAS module. Does is make a starter engagement noise at all? If Terminal 50 is bad then it won’t start unless the CAS gets replaced. I went through the same thing after a clutch replacement and my battery died in the process. If you can run a scan to check voltage during startup on that terminal. If it reads 0 V then it may be that.
Fatandre
12-21-2016 11:56 AM
WizardEyes
06-30-2013 02:15 AM
laxpimp6903
03-03-2012 04:26 PM
