Parking brake - no tension at caliper
Old 12-15-2018, 09:09 AM
blue_bomber's Avatar
blue_bomber
blue_bomber is offline
Just bought an '04 R53. Previous owner says he replaced both ebrake cables; and they do appear new. With the nut at full adjustment at the handbrake lever there is zero engagement of the parking brake; it's as if the cables have too much length. The spring mechanism at the rear calipers does not appear to be putting tension on the cable ends. Any advice would be much appreciated.
Old 12-15-2018, 12:44 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
routed wrong?
Caliper end not installed correctly?
Old 12-15-2018, 12:56 PM
blue_bomber
After messing with this it seems that the spring mech on the calipers are just frozen. I can tap/pull them to where the spring should return them when the handbrake is released and the cable lengths are fine inside. Once the handbrake is pulled and released the springs do not pull back the slack. Will this require a rebuild or new calipers?
Old 12-15-2018, 01:57 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
Are you 'up north'? Possibly encrusted with road salt etc ... (move to FL)
I'd give a soak with PB Blaster first ... or WD-40 if you can't find PBB ... soak for a few hours and work the mechanism and repeat a couple of times. If they don't free up you are looking at rebuild/replace
but be careful where you spray because ya don't really want this to get into the pads or rotors .....
blue_bomber (12-15-2018)
Old 12-15-2018, 06:13 PM
Tgriffithjr's Avatar
Tgriffithjr
Tgriffithjr is offline
blue_bomber (12-16-2018)
megaDan
How to
08-27-2018 07:46 AM
notasausage
Tires, Wheels, & Brakes
04-09-2018 03:39 PM
mikeym
15
01-08-2018 10:04 AM
cw40342
04-14-2015 07:11 AM
Quick Reply: Parking brake - no tension at caliper
