Oil Pump/Timing cover removal
Old 10-17-2018, 11:26 AM
kdefreitas11's Avatar
kdefreitas11
kdefreitas11 is offline
I have a 2004 Cooper S and I am trying to remove the oil pump/timing cover. I was able to remove all the bolts but the one with the star pattern. Number 8 in the image below. Also, is number 9 a special?
Could someone point me in the right direction to the proper tool I need to remove the (number 8) bolt?
Thank you
Old 10-17-2018, 11:35 AM
cooper48's Avatar
cooper48
cooper48 is offline
Someone correct me if I'm wrong but I believe No. 8 is a T27 Torx screw.
Old 10-17-2018, 05:33 PM
AoxoMoxoA's Avatar
AoxoMoxoA
AoxoMoxoA is offline
Originally Posted by kdefreitas11
...is number 9 a special?
The bolt itself is 'special' in that it's a hex bolt with an integrated gasket ring (p/n 07131485184) which should be replaced if you're removing it. As to removal, it's likely a very common 8mm or 10mm head.
As cooper48 stated, it's just a common torx bit needed for that bolt.
Not sure of the size I used when I did mine, but it's probably in the neighborhood of T27. No biggie.
Old 10-18-2018, 06:13 AM
kdefreitas11
Thank you both for your help. It looks like I need to order a new bolt with gasket ring and some torx allens.
Old 10-18-2018, 07:31 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Make sure to replace the internal oil inlet and outlet seals, timing case cover seal and crankshaft seal.
Refer to THIS documentation for reassembly details, tightening torques, etc.
silence2-38554
09-14-2017 07:44 AM
RexNTX
05-10-2017 06:05 AM
co0p3r
05-05-2016 06:59 PM
Marktheman
09-06-2015 06:15 PM
CORNERS
04-22-2012 02:08 PM
Quick Reply: Oil Pump/Timing cover removal
