05 Mini Cooper s overheating!!!!!
Was in traffic for a few today and out of nowhere temp jumped to almost 250. Stopped and waited a few, turned back on and temp didn’t go down, it fluctuates randomly and speedometer and rpm gauge didn’t move at all. Checked for leaks and didn’t see any, added a little water to coolant resorvoir, STILL SHOWING ALMOST 250 TEMP. I don’t want to start taking things apart unless it IS the issue that needs fixed. CAN SOMEONE PLEASE HELP ME?????
With the BMW system, it is critical the voltage when running is 14 to 14.5 volts.
The plastic coolant resurvior can be slip open and still look fine, but it will overheat, because it can not make pressure in the system. (these always fail with age)
Also, there is a burping threaded plug on the upper radiator hose, that can be loosened to bleed off air in the system.
1) low/high speed fan failure for radiator. - Confirm fan is working. Usually the .03ohm resistor (green) on the fan assembly burns out.
2) Check the cap for coolant expansion tank on firewall. Cap may be done, there is a built in spring in the cap, and often need to be replaced. Caps can be purchased separately or come with a new tank.
3) Expansion tank is split. ( odor of coolant cooking off when engine running ) check level.
4) The water pump runs off the supercharger on the drivers side ( U.S. Spec car ). If supercharger doesnt spin, neither does the mechanical water pump....is there boost ? I had situation where the internals for my R53 water pump were cooked.....not even sure how the supercharger was even making it spin.....
5) Crank Pulley failure, causing belt slippage resulting in supercharger not spining = water pump also not spinning.
Few things to check off top of my head.....
One other thing to do is swap out the thermostat. Simple easy thing to do.
By putting in a genuine MINI one in, the new thermostat stabilized the coolant temps to the point that the variance is no more than 10-12 C from putting around to hauling butt uphill. The fan rarely comes on high now, actually, I haven't heard it all since we changed the thermostat...
scubascott66
36
04-20-2022 07:23 AM
spirit
08-20-2012 07:48 PM
DJONEV
03-27-2010 07:30 PM
