help troubleshooting electrical issues
I have 2 electrical issues On my 2003 R53 to find and fix... before I start i知 hoping to get some advice/guidance to point me in the right direction. Issue 1 Warning lights: After changing the head gasket and servicing the SC, I now have the following warning lights on... ABS, TRACTION CONTROL, TIRE PRESSURE. I知 sure this is just a connector that is loose or that didn稚 get reconnected when putting the car back together.. so I plan on checking them all... but, before I start randomly checking connectors... is there a specific one that would cause this trifecta of warning lights? Issue 2 loss of electrical power: this issue was here before I took it apart to fix the head gasket. Car looses electrical power sometimes while ideling. When this happens all the gauges go dead and car stalls for a brief moment and then it all comes back on... I originally thought this could be a ground wire so when I had it apart I made sure to tighten the ground by the top engine mount and the ground on the altanator. I also made sure the battery terminals were clean and tight.... It is still doing it and I知 out of trouble shooting ideas. Does anyone have any ideas on how to trouble shoot an issue like this?.. |
Issue 1 - search on "trifecta" in this subforum. It is the best search key word. "trifokker" also should work know how smart google search is :lol:.
Issue 2 - have you checked the ground strap for the engine? |
Did you remove the subframe for any reason?
If not, come to a stop, hold the "!" button located in front of the parking brake handle till the TPMS light flashes, then drive above 15mph in a straight line for a few hundred feet and see if that fixes it. The other issue I would check the passenger side ground strap and both batter terminals for tightness. |
Originally Posted by JDM_
(Post 4409574)
I have 2 electrical issues On my 2003 R53 to find and fix... before I start i知 hoping to get some advice/guidance to point me in the right direction. Issue 1 Warning lights: After changing the head gasket and servicing the SC, I now have the following warning lights on... ABS, TRACTION CONTROL, TIRE PRESSURE. I知 sure this is just a connector that is loose or that didn稚 get reconnected when putting the car back together.. so I plan on checking them all... but, before I start randomly checking connectors... is there a specific one that would cause this trifecta of warning lights? Issue 2 loss of electrical power: this issue was here before I took it apart to fix the head gasket. Car looses electrical power sometimes while ideling. When this happens all the gauges go dead and car stalls for a brief moment and then it all comes back on... I originally thought this could be a ground wire so when I had it apart I made sure to tighten the ground by the top engine mount and the ground on the altanator. I also made sure the battery terminals were clean and tight.... It is still doing it and I知 out of trouble shooting ideas. Does anyone have any ideas on how to trouble shoot an issue like this?.. Issue 2: You battery may be at end of life. Mini Coopers need a good battery and 14.0 to 14.5 volts to keep everything running smoothly. Make sure the battery is good and high quality, as not all batteries are the same! Whith it running test to make sure you are getting at least 14 Volts. |
Thanks for all the replies.. :)
Tonight I'm hoping to have time look at these issues. Issue 1 Update: This morning I noticed the trifecta of lights had turned off... Then I hit a bump and they all came back on... So I'm thinking loose connector?? Downshift1: I did not remove the subframe during these recent repairs.. Issue 2: I will stop and have my battery tested today. |
Make sure to test the voltage while the engine is running, as it needs to be at least 14.0 volts. BMW wants 14.2.(test with digital meter is best.
The alternator, could be headed towards end of life, or terminals may be dirty, if you do not have the 14 volts. (don't assume the battery is toast) |
How is the brake level fluid in the master cylinder? If it's low, that could trigger the lights in the dash.....but the "brake" light should also come on if fluid is low
Your electrical issue could be a bad alternator as well....if a diode is out, it won't charge very well at idle Bryan |
Originally Posted by ItsmeWayne
(Post 4410026)
The alternator, could be headed towards end of life, or terminals may be dirty, if you do not have the 14 volts. (don't assume the battery is toast) I was able to get to the front passenger wheel speed connector (blue connector) I tapped and twisted it... As of now the warning lights have turned off! I'm thinking this is the guilty sensor connector. Issue 2: Stopped by Oreily's and had the battery and altanator checked.. They said both passed.. While there I noticed my + terminal was a little loose so I tightened it... Then came home and tested it using a multimeter.. Battery 16v Altanator 18v I used the setting "V DC" Was the correct? My #'s seem much higher than the 14v you mentioned. :confused: I let it idle for a while.. I did get an occasional low idle.. but I did not get the power flicker today.. That being said this is an intermittent problem that will not happen for a month then happen several times in a day... My fingers are crossed these issues are resolved.. I will update my progress... thanks for all your help :thumbsup: |
The 16 & 18 volts is too high.....I suspect a shorted cell in the battery with those numbers........
Then came home and tested it using a multimeter.. Battery 16v Altanator 18v I used the setting "V DC" Was the correct? My #'s seem much higher than the 14v you mentioned. :confused: You can also do a sanity check by measuring a fresh alkaline battery. |
Was I using the correct multimeter setting? V DC 200 ?
(Post 4410164)
(Post 4410171)
I just got similar readings with V DC 20.. I'll call the local Mini repair shop and see if they can test it.
Update:
My multimeter had a low battery and was giving false readings.. My new readings are 14.4v-14.2v And those dang warning lights came back on this morning on the way to work.. :confused: |
That is what you want to see!
Issue 1:
These lights have gone off and back on a few times.. Is there an affordable code reader that will tell me which wheel speed/ABS sensor to replace? I went the auto parts store and they said no code came up. I'm assuming this is BMW specific. Issue 2 UPDATE: After finding and tightening a loose + Positive battery cable.. I have not experienced this loss of power. I have my fingered crossed it was that easy of a fix. Thanks for everyones help.. This forum has a great group of Mini enthusiasts in it. :thumbsup: |
