North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-188/)
-   -   Mini R56 white smoke (https://www.northamericanmotoring.com/forums/stock-problems-issues/329405-mini-r56-white-smoke.html)
Pramuk 07-10-2018 09:47 PM
I have badly white smoke came out from exhaust after idle. My car has catless downpipe, no second cat straight pipe to muffler. I have replaced valve cover but the problem still remains. Is there any problem with engine or fuel system?
jglover 07-11-2018 01:16 PM
Water in the oil?
Blown head gasket?
Compression Test?
Pramuk 07-11-2018 02:39 PM
Originally Posted by jglover (Post 4405488)
Water in the oil?
Blown head gasket?
Compression Test?
No coolant in oil, I didn’t do compression test.
But it actually happened after I installed Catless downpipe. Then I got tuned but it helps a little bit.
cornjuice 07-11-2018 07:46 PM
how long have you had the DP installed?
what DP did you choose?
what level is your coolant tank? (low, full, overfull?)
**some coatings like ceramic etc can take a bit to burn-in and cause discoloration in the smoke and funky smell for few days/heat cycles
Pramuk 07-11-2018 07:48 PM
I have CNT V.3 catless downpipe(T304 stainless) Coolant normal level.
