Lost Power to Low Pressure Fuel Pump.
I have a 2010 Clubman S that has lost supply voltage to LPFP in tank. F43-20A fuse is good. The Relay in the passenger footwell #61366901469 is not the Fuel Pump Relay, although it does feed the Fuel Pump Circuit along with all the systems in the central dash console. There are parts listings for another relay Part #: 61-36-6-977-982-BOE for the fuel pump. If so where is it located? The other info I have found states the Fuel pump relay is integrated into the kick panel Fuse Box Housing and is part of the circuit board; which means replacing and recoding the Fuse Box (expensive vs a $20 relay).
I can wire in an external relay to feed the pump but I need to know which wire leaving the Fuse Box feeds the LPFP. All options considered. Thanks |
I have a similar issue, no reply on my post either
Lpfp
Originally Posted by tow hook
(Post 4447628)
Good luck with yours... |
Hi EuroMan,
May i know which relay u are referring to as i am having the same problem right now. If you can please share the part no for the relay would be much apprecaited. Thanks. |
The relay is a component part of the integrated circuit inside the JBE (fuse box). You have to replace the JBE. There are supersededpart numbers and you need to get the newest version. It will need to be programmed after install. Failure of the electronics is normally caused from water leaking past the sun roof drain lines. Make sure all leaks are fixed before replacing parts. My car was leaking at the right front and the right rear so my JBE and the HK stereo Amp had to be replaced. No help from Mini or my insurance company, so major $$$ to fix it.
Originally Posted by EuroMan
(Post 4464765)
Do you mean this relay - 61366901469 can't get it separately had to get the JBE? By the way, i don't have a sun roof. I have checked everything and come to conclusion that no power supply to low pressure fuel pump. The relay - is working fine but no per to field pump. I have also confirmed the wires to fuel pump is no problem. This what happened, after installed my hpfp and the new fuel filter it started but for after 2 or 3 mins, then it won't be able to start any more. Still working on to find the culprit. I'm taking the fuse box speg out now Any help will be much appreciated. Thanks. |
The replaceable relay you mentioned is not the one that feeds the LPFP. You will need to replace the JBE. If you take the old JBE apart , the relay is located in the lower right corner of the circuit board. It is soldered in place so very limited options getting the JBE repaired. While you have the JBE removed pull the carpet back and check for water underneath it. Also check your pin connectors for corrosion. If either are present, find and correct the leak before replacing the parts or you will be doing it again soon.
John |
John,
Thanks for your adivse. Will check and feedback. |
Hi John,
Had order new JBE should be here end of the week. Hopefully it will solve the issue i am encountered. Many thanks. |
New JBE should cure the problem. Make sure to unhook the battery before starting the work. Let car sit 15-20 minutes after key off to let system go to sleep. Unhook negative, then positive battery cables. Now you can start the JBE swap. Look at all the pin connectors. If any have green corrosion then you have had water intrusion. If any are heat damaged you will need to have the pin/connector replaced. Find and fix the leak before you install the new JBE. If you don't have a sun roof, water test around windshield and cowl. Check battery box lid and drain. The battery box is a straight shot to the passenger cabin. I drilled 1/8" holes in bottom corners of JBE case so if water does get in, it has a way out.. When done with JBE swap hook up battery, POS first then Negative. Should be good to go but sometimes it will need reprogrammed ( dealership) to get all functions ( doors, windows, wipers, etc...) working proper. If battery is not unhooked and hooked up correctly the system can put itself into " transport" mode. It takes an electronic key to fix this ( dealer only).
Let me know how it goes, |
minor clarifications:
1- you can use a used JBE/SPEG as long as it matches the part number. 2- coding and programming is not needed but is recommended. you could use WinKfp and NCS (almost free online but you gotta buy a $25 k+dcan cable...worth the money) 3- getting the car out of "transport" mode can be done via INPA (almost free online but you gotta buy a $25 k+dcan cable...worth the money) |
John & Minitobe,
Many thanks for the advise. Updates: I got a new JBE and it fire up right away. I have the ista-d with k+ dcan cable that enable me to get out of the TRA mode without problem. Unfortunately there are some errors. The errors are features that are not installed in my car. I don't have heated windscreen installed so it gave me errors. Not sure how to proceed now. Do i need to use ista-P to change VO ?? Your help is much appreciated. Many thanks. |
Good to hear that brother....if you have winfkp and NCS you can code it easily otherwise you may use ISTAP. If you go that route, make sure you're in expert mode. Make sure you ONLY select JBE. ISTAP has a tendency to select quite a few modules.
let me know if you need help with that :) |
Keeping my finger crossed that i recode it.
I have used ISTAP once to code my battery from 55mah to 70mah. I'm using k+dacn usb do you think it's possible to code JBE? Many thanks. |
ISTAP does not code like that...you're probably talking about ISTA+ or ISTAD. What other software packages you have for mini/bmw?
i have ISTA-P 3.66.0.200 with ISTAP loader v6.4
https://cimg2.ibsrv.net/gimg/www.nor...2dc644908e.jpg |
Aha good. Run it to program and code the JBE.
I will try it out on Monday and feedback.
Many thanks. |
Hey Guys,
Below is the faults that i am trying to eliminate : https://cimg3.ibsrv.net/gimg/www.nor...79a93ad981.jpg I have not tried connecting the USTAP to the vehicle yet. As for the ISTAP I am using K+DCAN cable not the ICOM, not sure it will work. To keep the story short, i have installed a new JBE and these are the fault code that appear after that. Before install the new JBE these fault code were never there, the reason for new JBE was diagnosed with K96 fuel pump relay faulty. The other thoughts is that i don't have windscreen heater installed from day one but now it is complaining that can't find the windscreen heater. Any help or suggestion will be appreciated. |
Originally Posted by MiniToBe
(Post 4466101)
Yes, i have setup to use the EDIABAS as my connection.
Will give it a try tomorrow. Many thanks. |
(Post 4466423)
when load ISTAP, go to settings and choose Ediabas as your connection. that's how you utilize the K+Dcan cable.
One silly question what should i be coding for a new JBE installation, kindly explain as i have not do any major coding with ISTAP. I am so afraid of screw up the program in the car. Sorry to trouble you. Many thanks. |
When you fire up ISTP, it gathers the proper information from your CAS. So, the only thing you need to do is select JBE to be programmed and coded. ISTAP will automatically do that. You dont have to get into the trace file and change anything like you would for NCS.
Post pix and i can walk you through it or pm me. |
(Post 4467116)
Post pix and i can walk you through it or pm me. Thanks. |
(Post 4467116)
Post pix and i can walk you through it or pm me. Is it possible not to update the ecu to the latest version and just code the JBE? Anyway, i didn't proceed with the actions list. https://cimg2.ibsrv.net/gimg/www.nor...d210378e65.jpg Control Module tree https://cimg3.ibsrv.net/gimg/www.nor...65bed0ba3a.jpg Process control modules https://cimg4.ibsrv.net/gimg/www.nor...3e7f9db7cc.jpg Actions list |
