Newby that went to half power
Old May 21, 2018 | 10:58 AM
Tjsb03's Avatar
Tjsb03
I have an 09 R56-S that has k&n typhoon and Borla exhaust, I just went over 105 k and had the half power light come on. Other than no power, the car runs great. No noises, hisses etc but no turbo power. I thought it was because I used bad gas but have ran good with octane boosters. Any ideas?
Old May 21, 2018 | 11:43 AM
H_C's Avatar
H_C
Got an OBD II scanner?
Maybe someone local can lend you their scanner.
Old May 21, 2018 | 12:33 PM
Tjsb03's Avatar
Tjsb03
Thx
I went to autozone that said I had a cyl 2&4 misfire and probably due to bad gas but hate to think it still runs great except boost and nothing I can do without paying a fortune
Old May 21, 2018 | 12:55 PM
H_C's Avatar
H_C
What's the condition of your turbo? Any oil or vacuum leaks?
Unless you're using really old gas, its really doubtful that your issue is directly related to "bad gas".
If you think that's the case, you can drain it and pump 1 gallon of new gas.
Old May 21, 2018 | 03:10 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Gen2 Stock Issue/Problems section.
Old May 21, 2018 | 03:53 PM
sawicki's Avatar
sawicki
Swap coil packs around and see if the code follows.
Old Jun 20, 2018 | 08:09 AM
Tjsb03's Avatar
Tjsb03
Still searching
I replaced nearly every sensor and vacuum lines. Checked the vacuum “can” and didn’t leak. No oil or wear around the turbo. When vacuum is applied, turbo valve open and closed. Vacuum pump sucks! Hpfp was replaced by previous owner. Valves need blasted but didn’t know if this would cause the ecm to shut down boost? Bov is fine. Car runs great other than lacking the power from the turbo?
bill12s
Mar 23, 2017 02:57 AM
5810
Aug 25, 2013 09:07 AM
MiniCarver
R55 :: Clubman Talk (2008+)
Sep 25, 2009 01:55 PM
EBee
General Discussion
Jul 29, 2009 03:39 PM
diablito
Off-Topic :: Autos
Nov 9, 2008 07:11 PM
