Replaced my Fuel Filter and now my car wont start
Old Mar 14, 2018 | 06:18 PM
Codie Flanagan's Avatar
Codie Flanagan
After reading the forums and i decided to change my fuel filter. everything went pretty smoothly. i remembered to replace all the gaskets. everything seated nicely.
i primed it and i went to start it and now it wont start. it cranks and cranks but its not getting fuel for some reason. what could be causing this? i took everything back apart and checked and it all appeared good.
i have a 2012 mini cooper S
Old Mar 14, 2018 | 07:33 PM
BigBoost's Avatar
BigBoost
Yeah without being there’ it’s kind a hard to diagnose it !! Are you sure you didnt pull an electrical lines out or anything like that’ plug ever thing back in,
Old Mar 14, 2018 | 07:36 PM
Codie Flanagan
Plugging things in
The only thing i unplugged was the negative lead on the battery and the fuel line. both of which were re installed after the filter swap
Old Mar 14, 2018 | 07:38 PM
Codie Flanagan
inertial fuel shutoff?
The fuel pump doesnt sound like its turning on when i try to prime it.
Old Mar 14, 2018 | 07:51 PM
BigBoost's Avatar
BigBoost
You sure you didn’t unplug something from the bottom of the filter housing . I would double check all of that
Old Mar 15, 2018 | 04:57 AM
MiniToBe's Avatar
MiniToBe
get a light tester and check of you have power to narrow down problem area. also, clear codes even if you dont see CEL. lastly, remove the fuse and reinstall it to "reset" the pump.
Old Mar 20, 2018 | 06:08 AM
patpatpat's Avatar
patpatpat
put the old fuel filter and see if it starts. If it does, then you have faulty new filter in your hand
frankiev
Jul 19, 2018 09:35 AM
themarques
Mar 29, 2018 11:55 AM
KevinR
Apr 2, 2016 08:31 AM
themarques
Nov 12, 2015 12:37 PM
RatBlast
Nov 20, 2008 08:46 AM
