turbo motor from a 2012 R55 Sinto a 2011 R56 S HALP PLEASE
Old 06-14-2018, 12:59 PM
jpauley's Avatar
jpauley
jpauley is offline
Ohhh I’m definitely not saying your wrong I’m fully assuming that the info I had prior to now was bad. Easyish *** though. Which way do you fill the trans? I’ve been using the 12mm bolt on the side of the trans case.
  #27
Old 06-14-2018, 01:10 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
you should use the T55 one in the back facing the power steering motor. It is hard to break but airtools make it easy...I used to unbolt the rear motor mount to get more space
  #28
Old 06-17-2018, 04:24 PM
jpauley's Avatar
jpauley
jpauley is offline
So I check the fluid with the car running but can I add the fluid with the car running?
  #29
Old 06-18-2018, 05:57 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Sorry for the late response....yes you can add fluid while running...once it starts to trickle from the drain plug, close it, run through the gears slowly then check fluid again. Add a little bit this time and once it trickles, close it and take it for a drive.
  #30
Old 06-20-2018, 08:10 PM
jpauley's Avatar
jpauley
jpauley is offline
Your a genius! I did it the way you said and ended up getting 1.5 more quarts in now it runs great.
  #31
Old 06-20-2018, 08:36 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Im happy I was able to help
  #32
Old 06-20-2018, 09:53 PM
jpauley's Avatar
jpauley
jpauley is offline
It’s funny I have a group of guys who hang at my shop they see me go through this and keep saying things like “never again dude” I’m here thinking I learned a ton and next time it will be way easier. I appreciate all the knowledge and help I gained here. Now I have to put a down pipe, cat back, and hpfp in a R56-S manual. I kinda like these things to be honest now that this one is shifting good it’s a riot to drive.
grueinthebox
05-25-2019 10:46 AM
skakid812
12-26-2009 10:19 PM
Mr. S.
11-10-2009 03:57 PM
austinapril
06-12-2008 08:09 PM
ChrisLaw
Bluegrass MINIs (Kentucky)
01-16-2008 06:19 PM
Quick Reply: turbo motor from a 2012 R55 Sinto a 2011 R56 S HALP PLEASE
