Secret Compartment, Upper Glove Box,FIX
If your upper glove box (secret compartment) only opens a little bit, here is the fix. Shut up, it's not a secret, you're reading this post.
I'm new to mini's but I enjoy ripping things apart. I'm not one to post up "how-to" posts but I figured my first post should be valuable to someone. I just purchased a 2011 R56 and the secret compartment above the glove box would only open about an inch. I spent about 45 minutes removing the glove box and eventually lost my cool and ripped it out. That's fine. I was going to replace it anyway with a new one that I ordered on eBay. Unfortunately the new one ALSO would only open about an inch. After playing with the glove box for about an hour I figured out the issue, and I figured out how to correct it. 1) Remove your upper glove box. This is going to take more time than anything else, take your time. 2) Once it is fully removed, on the left hand side of the hidden glove box you'll see this little aluminum piece. This appears to be the cause of all your (and mine!) problems. It rotates just slightly and if you hit a bump while the box is closed the piece I circled bounces into a position that prevents the box from opening. The only way to get the metal piece back into the proper position is to rotate the metal piece back into the upward (shown here) position...OR...remove this damn piece that appears to do nothing but wreak havoc on our hidden glove boxes. https://cimg5.ibsrv.net/gimg/www.nor...511f8c186f.jpgThis piece is your problem. Here is is in the proper "up" position. Your box can open and close properly. https://cimg8.ibsrv.net/gimg/www.nor...95f315d46c.jpg Here is the same piece rotated in the downward position. In this case, the compartment could not close properly. If your metal ****-piece has fallen out of place when your box is open, you can no longer close it. If your metal ****-piece has fallen out of place when your box is closed you can no longer open it. Make sense? Good. 3) Now I have not been able to find any reason why this little spring loaded piece is here. It is not attached to any other mechanism and does nothing other than cause a problem. Use some needle nose pliers and gently remove the metal spring. Each end goes into a hole on the glove box, so removing it takes about 1.4 seconds. It's easy.... If you aren't in the mood to be gentle...just rip it out. F*^$ that piece it's garbage. 4) Now position the metal piece as shown, and lift it out of its seat, and out of the box entirely. https://cimg3.ibsrv.net/gimg/www.nor...6f587a3a50.jpg 5) DONE. Your box will function normally. I'd suggest adding a little brake grease or WD40 to all of the gears and then reinstall it back into your car and you won't have any issues. 6) Take your metal piece and spring to your closest Mini dealer and ask them why this exists, demand they locate the engineer. If you ever find out who engineered this, put them in contact with me. I have several questions for them...like why is this here? why would you do this to me? who hired you? can I have your job? UPDATE: Your metal spring may be in a slightly different position, I took these photos after fully removing it and I was too lazy to put it all the way back together just to get a photo for you. |
Welcome to the forum
I haven't figured this out yet, but do the auto industry hire the smartest from the universities or the hungover drunks that like to play pranks now and then? No matter what manufactured vehicle I've owned, there are comments I can make about each them like this. |
I just bought on ebay a cheap glove compartment, so I could change the color of the trim and it was blocked. Turns out that that spring has to be *inside* the metal piece, as it will retain it in the correct position.:thumbsup:
Originally Posted by Carrboroman
(Post 4408604)
Originally Posted by RaymondS
(Post 4408607)
Yes, I believe I mentioned that in my original post.
If you just remove all that nonsense (spring and metal piece)...it will always work...because those two pieces have no actual function that I or anyone else has been able to identify.
edit: to elaborate, the piece seems indeed made to lock the rail, https://cimg5.ibsrv.net/gimg/www.nor...5c49b2a5fb.jpg hooking in the plastic fins of the other part (red arrows): https://cimg2.ibsrv.net/gimg/www.nor...d60a49fa1b.jpg in my case, positioning the clip this way is preventing movement whatsoever, the other box is the same and I probably have been lucky these years. https://cimg1.ibsrv.net/gimg/www.nor...bf378fdbf9.jpg Anyway, if that thing could be accessible, it would make somehow sense, but this way...maybe it is just for when shipping the assembled unit, so the part won't pop up when opening the box...who knows. |
How to remove?
Great info, but how do you remove the upper glove box if you cannot open it? All the info I can find has the first step as "open the glove box"
Good question - my "secret" glove box won't stay closed & I removed all the obvious screws but it still wn't budge & It's not something I want to waste time on, so I just wedge the the useless thing closed.
-Oly |
I know this post is a couple of years old but I wanted to add that the reason the locking mechanism is there is to prevent the door from opening during a front end collision and interfering with the air bag. I have a MY15 F56 and the spring mechanism is completely different, it is a little coil spring and post that engages the latch and locks it into the "locked" position.
Always fun to see how they go about addressing function and safety. Nice thread.
