Engine not turning over
Old Jan 13, 2018 | 03:52 PM
burley's Avatar
burley
I'm parting out an R50 and have disconnected and sold a few things, non of which are engine related. After a few months, I have a buyer for the engine, and he wants to hear it crank before he buys it. I shot a video of it running to avoid this scenario, but he still wants to hear it in person.
So.. With the driver's seat, steering wheel/airbag, headlights, rear view mirror (which recognizes the fob), right airbag sensor, and a few other things removed, it wont turn over. The battery is in good shape, and I've tried jump starting just in case.
When I insert the key, and turn to position 2, something winds up and whines very loudly. The wipers and windows dont work right away, but as the whine goes away they start to work.
I want to say its something simple, but I'm baffled. Honestly, I never kept track of things I unplugged because I never planned on starting the engine ever again, but I want to say nothing important was disengaged.
Ideas?
Old Jan 13, 2018 | 06:08 PM
Whine not Walnuts's Avatar
Whine not Walnuts
If he just wants to hear it crank, couldn't you hot wire the starter and get the engine to turn over?
Old Jan 13, 2018 | 06:11 PM
burley's Avatar
burley
Those kinds of shenanigans worked on my old Jeep CJ5. I’ve never tried that in a modern car, but seems logical. I said he wants to hear it crank, but I meant run.. I don’t think hotwiring the starter allow the motor to run, correct?
Old Jan 13, 2018 | 06:18 PM
Whine not Walnuts
Running and cranking are two different things for sure. I would not even want to think about what type of hot wire harness you would need to get the thing running.
Old Jan 13, 2018 | 06:45 PM
burley's Avatar
burley
I shot a video of it running and included the odometer, which reads the exact same mileage today when you stick the key in the ignition. I dont know what else you could ask for from a parts car. He's going to have to take a leap of faith.. I'm not going to problem solve this one.
Old Jan 13, 2018 | 09:10 PM
thatminicarguy's Avatar
thatminicarguy
I would refer him to your great reputation on this site
Old Jan 14, 2018 | 05:01 AM
Whine not Walnuts
If the mileage is the same today as when the the video was created, IMO the guy has problems, not the engine.
Old Jan 14, 2018 | 06:55 AM
burley's Avatar
burley
LOL! Thats what I thought! I showed him service records and the video. Its not like vehicles spontaneously die at idle. Its a part out car, and there are hundreds of reasons why it might not run at this point. I dinked around in the garage till 1am trying to hook everything up with no joy.
I'm done, he can take a leap of faith or find another engine. I'm not spending another minute trying to get this running. Dont most people who sell engines have them sitting pallets??
Old Jan 16, 2018 | 10:44 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
You could jump the two poles on the starter with a piece of wire, actually! As long as the battery is good, it should turn the starter over.
Edit: Ope, I'm dumb. You want it to start, not crank. Hmm..is it turning over with the key at all? Are you sure everything in the bay is plugged in--coil pack, grounds, injectors, etc?
And yes, they do. I've gone to look at 3 or 4 that have just been sitting inside of tires/pallets/etc.
Old Jan 16, 2018 | 10:47 AM
Whine not Walnuts
Getting the starter to turn is the easy part, the question is whether the fuel pump, coil etc are all going to function.
Old Jan 16, 2018 | 11:26 AM
burley's Avatar
burley
There’s a chance the gas line has air in it since I cut the line to use the part that connects to the fuel rail on my other cooper. I’ve reconnected it, and I know there’s pressure because for a moment before I tightened a clamp it sprayed gas, lol. I can hear anything when u turn the key. Not even a click.
Old Jan 17, 2018 | 12:02 PM
sarom058's Avatar
sarom058
If you aren't getting a click, the starter solenoid isn't getting power.
Eliminate the starter first, because they seem to go bad from just sitting. A wire across the two poles will make it spin, if the solenoid is functioning.
If the starter works via hot-wire, then try fuses.
Next, check all your grounds.
Finally, double check all the wires are plugged in. I know it's silly, but who knows?
Also, the high pitch whine under the motor you hear when you turn the key is the P/S pump. The quiet low-pitch groan behind you when you first turn the key to pos2 is the fuel pump. Saw your comment earlier, just figured I'd clarify, for science
sarom058
Nov 2, 2017 11:20 AM
bansasn
Apr 27, 2017 03:08 PM
hoodie
Classic Mini Talk
May 7, 2016 02:14 PM
SirArconas
Mar 6, 2014 06:30 PM
STEWIE
Detailing 101
27
Apr 25, 2007 08:26 AM
