2004 Mini Cooper S Won't Go Above 2,000RPM
Old Dec 13, 2017 | 10:49 PM
nhack's Avatar
nhack
I was on my way home from work tonight when all of a sudden my car wouldn't let me go above 2,000RPM after I turned onto my street. Keep in mind it was snowing all day and I was a mile away from my house. When it happened there was no indication that let me know what the problem was. No EML or audible noises from the car. The car ran and sounded the same as usual. It also doesn't seem to have power under load. This happened out of nowhere and I don't know what to do.
Old Dec 14, 2017 | 04:33 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
probably crank damper failure 2004 may have the newer style so it's really hard to see if it's failed I had to get under the car and inspect it there. Mine did the same thing, power normal until 3000 then it would slip. Got worse and worse on my limp home
Old Dec 14, 2017 | 06:22 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues area.
Even thought you had no EML, did you check for any codes? Sure sounds like limp mode.
Old Dec 14, 2017 | 07:52 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Very well could be a crank pulley. Time for an ATI damper.
Old Dec 14, 2017 | 01:52 PM
nkfry's Avatar
nkfry
The car will still rev to redline if the crank pulley is failed, are you sure that DSC wasn't trying to control wheel spin?
If the car doesn't have power, has a battery light, or is starting to over heat it could be a crank pulley issue. Do you notice a burning smell, like rubber?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 14, 2017 | 03:04 PM
MrBlah's Avatar
MrBlah
mine would not, it threw a fault and wouldnt go over 3k
tntaussie
Mar 15, 2022 03:23 PM
Hizapitt
R60/R61 Stock Problems/Issues
Jan 28, 2014 07:01 PM
PaytonR56
Sep 30, 2013 07:48 PM
jamiebean1980
Jul 26, 2010 07:53 AM
Moskito
Apr 5, 2007 06:59 AM
