2006 Mini Cooper S JCW Engine Noise
Old Nov 26, 2017 | 08:45 AM
jaypark28@gmail.com's Avatar
jaypark28@gmail.com
Hello all,
Unfortunately my 2006 Mini Cooper S started making noise from passenger side of engine a few weeks ago. The sound can be described as metal clacking sound and present at idles and present in all RPM ranges but goes away around 2.9k to 3.3k. I did not go above 3.3k rpm fearing that I will do further damages. I managed to borrow one of my friend's stethoscope and it seems the sound is coming from the park that connects intercooler to supercharger unit.
The car actually drives ok without any other warning light or symptoms.
Can anyone help me identify the source of the issues? Based on search it seems either supercharger or timing belt guides? Any my comments and help would be greatly appreciated.
Old Nov 26, 2017 | 09:09 AM
Scudder44's Avatar
Scudder44
Sounds 100% like the timing chain is slack. You could try changing out your tensioner as a first fix. The tensioner has had several revions and has been uprated. If that does not fix it you are looking at chain/guides/sprocket replacement sooner rather than later because a loose chain can derail/jump teeth, smash the plastic guide rails and wreck your valves and more.
Old Nov 27, 2017 | 08:47 AM
Could be the tensioner or the guides, those are the first two things i would check.
https://www.northamericanmotoring.co...tensioner.html
Old Nov 27, 2017 | 09:25 AM
jaypark28@gmail.com
Thank you all for the comments. Turned out to be my supercharger. There were some metal shavings inside the pulley side of the supercharger and I presume that the metal shavings are from bearings/spacers behind the gears. One of the gears has some play. So in need of a supercharger.
Is the supercharger unit different for JCW vs. regular Cooper S?
Thank you!
Old Nov 27, 2017 | 09:27 AM
Yes JCW has a reduced pulley size and the Teflon coated rotors. Unless you have a 2005+ MCS, then they were Teflon coated also.
Old Nov 27, 2017 | 06:08 PM
jaypark28@gmail.com
So will be getting either rebuilt or used supercharger in next couple of weeks. What other parts/seals/gasket should I replace as "while I am there" items? another member said he replaced the following items. My car has approx 80k miles.
SC intake air duct
Water pump
Serpentine belt
Belt tensioner (no tension)
3-pc radiator hose
Air duct gasket
Throttle body gasket
SC oil
Thank you!
Old Nov 28, 2017 | 02:56 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Crank sensor o-ring as you will be in front service mode.
And if you are looking for some more performance, yes your MPG may suffer (from your foot hitting the gas more by accident of course), a Detroit Tune Bypass Valve. It lowers the vacuum point that the SC will kick in.
