R56 oil leak - already think I’ve hit most of the usual suspects
2008, R56 Turbo, 70K miles.
Oil is leaking from somewhere high on the back of the engine block. So far, have changed
valve cover gasket, crankshaft seal, breather tube from valve cover to intake manifold and
throttle body rubber intake pipe. After 5mins of idle,line of oil appears on passenger side (left side of engine if looking at engine) close to engine mount, rear of block. Hard to see where it’s coming from but pretty sure it’s above the oil pan gasket but below the valve cover. I removed the intake manifold to see more, generally oil smeared around block, below the head gasket line. Any suggestions on what might be leaking? I’m planning to clean really well, reassemble and repeat to see if I can see the source but any suggestions in advance would be much appreciated.
Andrew
Andrew
