Wheel speed sensors - OEM vs aftermarket
Old Nov 15, 2017 | 04:47 PM
Duaneo's Avatar
Duaneo
Folks,
I've got the trifecta of lights going on, and I'm looking at replacing a wheel speed sensor. I see that the OEM part is as much as $150 where the aftermarket part is as little as $30. Is there a difference in quality? Has anyone had issues with the aftermarket parts?
Thanks,
Duane
Old Nov 15, 2017 | 05:39 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Originally Posted by Duaneo
Folks,
Thanks,
Duane
There is a very recent thread that the owner bought a cheap sensor, only to have problem. He ended up having to buy an OEM one and the problem was resolved.
Old Nov 15, 2017 | 08:37 PM
RUPNOK's Avatar
RUPNOK
That was me. Do a search on ebay for a siemens/vdo sensor for $60. It will work.
Old Nov 16, 2017 | 05:24 AM
I have use the oem ones and the vdo, they are the same. But with these sensors no matter what they are you have to watch installing them as the heads tend to crack if too much force is placed on install. You have to clean out the hole really good on the old mount location and also watch those wheel bearings.
https://www.northamericanmotoring.co...ed-sensor.html
Old Nov 20, 2017 | 09:36 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
I'm gonna differ here. Those sensors are total crap anyway, these cars drive best with traction off. Mount it correctly, cover it with the fender liner, and all will be well. If it's really that hard to replace, buy the fancypants sensor next time. Worst case you have to remove the fender plastic again.
There's one on rockauto for like $10. Buy 10 (if you want) of those and replace them every few months, and it'll still be cheaper than one OEM one, lol. It's a piece of cake to replace, shouldn't take more than 10 minutes after you get the hang of pulling those little trim clips. Totally not worth going OEM.
ECS is totally right on the install, though. Just don't use an electric impact on plastic and you'll be golden
Old Nov 20, 2017 | 09:46 AM
Tell me about it I learned that hard way and cracked one forcing it in and did not know till I had it back all together and wondered with the trifecta lights were on.
Old Nov 20, 2017 | 10:29 AM
pnwR53S's Avatar
pnwR53S
While there were reports that the lessor brand sensor didn't work but the OEM ones does. I suspect the cheaper ones were damaged during install, or due to defective tone ring. These sensors are quite simple so paying genuine MINI part price is flushing $ down the drain.
However I would not want a malfunction sensor as it is used by ABS as well as flat tire warning sensing. I was wise to not order the DSC, so I only have AST. I cannot tell you how many times AST tried to kill me.
Now in my standard preflight check list the first item to be tick off is - is AST off?
ABS is a totally different matter. It let me drive with more measured recklessness.
Old Nov 20, 2017 | 11:21 AM
sarom058's Avatar
sarom058
Same, lol! Well, not with the speed sensors. But with my heat exchanger bolts...Way ended up adding used bolts to his site because of me...you're welcome.
I think it has to do with the fact that we all learned from ModMINI, and he's a pro with the impact. So when we watch his videos and see him install a bolt with an impact, we do the same. But it's hard to notice the little nuances, like how much lateral pressure he applies to the bolt using the impact/how he backs off on the trigger towards the end, etc. So we end up doing stupid stuff, like breaking the terminals off of our battery cables, or stripping little torx bolts, or cracking our cam position sensors
Yes!! While ABS is definitely a nice modern feature, it's not intrusive. And it doesn't affect the driver's inputs at all, it simply pulses brake pressure to prevent wheel lockup. It's actually rather nice, because it intuitively teaches the limit of braking pressure before lockup.
What's the difference between AST & DSC, though? I just know that having it on prevents throttle saves in hairy corners because it cuts power completely when cornering any faster than "granny-speed". (sketchy) I just always make sure the happy little yellow circle is always illuminated when driving spiritedly.
Old Nov 20, 2017 | 11:44 AM
pnwR53S's Avatar
pnwR53S
For this reason, I seldom pull out my pneumatic impact wrench or air ratchet wrench. I prefer to take my time and not kill expensive parts. Even if the part is cheap, waiting for the transit time is just not worth the time saved.
AST is the crap overreaching engine power management that cut power when a front tire starts to slip. DSC has AST plus computer-aid stability control. From what I read it is not that great give the era of circa 2000 design. Today some stability control systems are very very good, especially for high power cars like Porsche even for good drivers on tracks.
For me AST may be marginally useful if you has no LSD, and try to start on an icy slope.
Old May 26, 2023 | 12:05 PM
Jblazzze5842's Avatar
Jblazzze5842
Folks,
Thanks,
Duane
I had 2010 Prius and had to replace the rear speed sensor. After seeing the price at all the local shops(autozone, advanced auto parts, napa etc.) being damn near around 300$ I decided to look elsewhere. I ended up finding one on ebay for 15$ took my chances purchased and installed it. I never had a single issue with the 15$ sensor I got off ebay and highly recommend giving it a chance vs the alternative.
