Odds of my ball joints needing replacing?
R53 57,000 miles, control arm bushings are shot so I am planning on dropping the subframe to replace them with new ones and while I am in there replace the lower engine mount that is cracking and the sway bar bushings on top of the control arm bushing mounts.
I am figuring my inner ball joints are ok, is that a fair assumption for the miles? Outer is easy enough to replace later if needed.
Vendor
It's hard to say if they will be ok. But they will be a lot easier to do while you have the subframe down. That is why most people do them as to not have to do the labor all over again.
Also a good time for the powerflex steering rack bushing since it will be easier too.
Oh jeez, I'm not sure in that case. They go until they break, and they usually bring with them lateral slop and pinging over bumps. I guess if you're trying to go super-safe, you could replace the inners preventatively whenever the subframe comes down, and leave the outers up to a semi-annual inspection, as they're relatively easy to replace if you have a ball joint separator.
What year is your R53? If they aren't damaged and don't need replacing, but you're going to be in there anyways, you might as well replace them as a preventative measure. I recommend Lemforder as they're the OEM supplier: http://www.pelicanparts.com/catalog/...pg5.htm#item20. If you ever have parts questions please don't hesitate to reach out to me and ask. I am here to help.
888.280.7799 | 6am - 5pm PST
If you are going to have the subframe out....just replace them. I pulled my subframe and put in new LCA bushings at around 80,000 miles. I didn't replace the ball joints......well, because they weren't making any noise and looked fine.
Well.....at 85,000 miles....they start making noise, so I had to drop the subframe AGAIN and replace the ball joints.
Just replace them now....or you could be kicking yourself later like I did
sarom058 (11-14-2017)
If you are going to have the subframe our....just replace them. I pulled my subframe and put in new LCA bushings at around 80,000 miles. I didn't replace the ball joints......well, because they weren't making any noise and looked fine.
I second that! I recently did mine while putting in poly LCA bushings. As most seem to be, my ball joints were a pain to get out without air/impact tools. But what did the trick is a pickle fork on the inners and a cold chisel set + 4lb. hammer for the outers. Best of luck to you!
Also, I guess I should rescind my previous statement. Trust these guys. Dropping subframe just for inner ball joints would suck. I didn't think about that.
When you do the job, make sure you pick up , though! They will make the job a breeze! Plus it's so much fun to explosively *POP* the ball joints out with this method. And later on, if you ever have to remove them, you can reuse them if they were removed with the seperator!!
