Engine Knock and Trouble Starting
Hey Guys,
So my R53's been doing some strange things lately that I haven't really been able to trace. To start, I did have the subframe dropped early last month to change control arm bushings and I recently installed a 15% pulley. I've been getting the engine knock code since I've reinstalled the subframe, and have also noticed that that there's some hesitation higher in the rev range. Nothing crazy, just seems to trip up once or twice, but seems to be doing it more recently. Its also having a little trouble on cold starts as well. I have to crank it for a bit and it struggles to turn over. Sometimes requiring a second try, which leads me to think the fuel pump is on its way out.
So far I've checked out the engine mounts which appear to be fine, and changed out my spark plugs (the old ones were toast), but nothing seems to be helping. I was wondering if you guys had some leads on some other avenues to investigate before I start going for the fuel pump.
Thanks!
Nick
EDIT - I should also note that the coil and plugs were replaced 3 months ago as well
Thanks!
Nick
Hey Guys,
Thanks!
Nick
Thanks!
Nick
nthomas7883 (10-10-2017)
I’m sure you will get it Sorted! A lot gets fiddled with the subframe out. I would check all your grounds, remove , inspect and reinstall the plugs- making sure the crush rings are snugged up. Assuming you disconnected the battery with the earlier repairs- I would double check those connections also. I would agree about your fuel pump observation, but that sounds like an additional item- not the main cause. Keep looking and keep us posted. Good luck.
The code I'm throwing is P0326
I might also revisit the engine mounts as well, I noticed later today that theres a noticeable shake at idle. I might take a look tomorrow and see if I can source it!
Thanks guys!
-Nick
The secondary parameter for that code is the engine coolant temperature along with engine load and speed. I would check all the plugs and wires down by where you were working. Have you checked the values on the speed sensors?
On the starting, how many miles on the car? Plugs and wires been changed recently?
For long distance diagnosing, the more information there is the better chance of making some guesses.
Right now I'm sitting right at about 127k miles. I put in an MSD coil with VMS wires in June, and new plugs not even two weeks ago.
I'm going to do some data logging via dash command so see if I can spot anything out of the ordinary over the next few days.
So just to be sure he cleaned the knock sensor plug? FWIW I'll have to take off the supercharger to get access?
Thanks for the responses guys! The Mini's sort of a work in progress, and first step is just maintaining it :P
-Nick
