Gushing out coolant near the Thermostat
Old 06-27-2017, 02:26 PM
Sayeed's Avatar
Sayeed
Sayeed is offline
Friends,
My 2009 Mini cooper Clubman coolant is like gushing out near the thermostat housing. I am hoping it's just the housing.
I put a small video - any help would be appreciated.
https://youtu.be/v-YLQD0cP9g
Old 06-27-2017, 09:24 PM
spyder152's Avatar
spyder152
spyder152 is offline
Video not working, I just did mine two weeks ago, not horrible, I would suggest replacing the plastic pipe that connects to the water-pump while your at it. That's where my leak ended up being.
Old 06-27-2017, 10:14 PM
Sayeed's Avatar
Sayeed
Sayeed is offline
Found the problem
The Thermostat housing was cracked and melted - poorly designed and location.
Old 06-28-2017, 05:41 AM
HillbillyChili's Avatar
HillbillyChili
HillbillyChili is offline
You could look into getting a metal housing, I'm sure you don't want to wait around for parts but I bet there is one out there. I know they have them for Gen 1.
Figure since it happened once it might happen again, design flaws.
Old 06-28-2017, 06:52 AM
mashby's Avatar
mashby
mashby is offline
It's a horrid part and so overly complex for no reason.
Unfortunately, I have not found a metal replacement part. If you do find one, please let me know.
Old 06-28-2017, 02:33 PM
sikamini's Avatar
sikamini
sikamini is offline
It is all of that. I wouldn't mind a metal one as well, but suspect one will not be made because of the complex design. The plastic tube connecting the pump and thermostat gets brittle too. It would be nice if that came in aluminum as well.
Old 07-05-2017, 11:32 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
No metal one as of yet. It's so complex and so touchy with the electronic thermo, most likely it will be years till it comes out, if ever.
I replaced mine with the newest part number and it outlasted the old design in mileage. While you are in there, i did my switch to the metal water pump, new water pipe, and did expansion tank also. Then flushed the system and its been good ever since.
https://www.northamericanmotoring.co...8-no-heat.html
