Leaky thermostat housing permanent fix?
OK I bought my 2006 Cooper new and it now has 180,000 miles on it. It has definitely seen better days but it still going strong.
I had the thermostat housing replaced under warranty and I've done it myself two times after that. Well it's time to do it again...
Is there a permanent fix for this problem? I typically just get a new housing and gasket but I'm wondering if I should put some sealant on there or something? Anybody else have this chronic issue?
It seems like every couple months I'm doing brakes, tires, or the thermostat housing...
Vendor
Shouldn't put any sealant on it. But also there was a few updates to the thermostat gasket. So we ONLY use the factory original MINI thermostat and gasket as they are the most reliable.
https://www.waymotorworks.com/thermo...t-r50-r53.html
And the new housing
https://www.waymotorworks.com/r53-th...t-housing.html
And the new housing
Yeah I'm cleaning the motor service off with acetone and a Scotch-Brite and torquing down to the required torque. My latest repair actually lasted longer than the dealers and the original factory installation.
thanks for the heads up, I will get the updated thermostat housing and gasket and see if that works. I hope the car has another 50,000 miles left in it!
