Squeak and knock 06 MCS R53
Old 05-15-2017, 05:55 AM
Mini_Garage's Avatar
Mini_Garage
Mini_Garage is offline
Hello guys this is my first post on this site and was hoping to find an answer or two. So my 06 MCS started all of a sudden making a squeaking and like knocking noise. i first jumped to the idea of valve slap due to a failed tensioner. but then i realized the 1.6 S/C Lisa motor isn't an interference motor. I replaced the tensioner and the noise persisted. i then jumped to the conclusion of the crank pulley, i ordered one and it has yet to come in. Although i believe its the crank pulley, it doesnt seem to wobble or be separating. The symptoms are:
-Knocking
-Squeaking
-Hard Start
-Oil Light (might have a bit much oil tbh)
-Car also has 143,000 Miles on it
thanks guys, any ideas helps!
Old 05-15-2017, 10:32 AM
RUPNOK's Avatar
RUPNOK
RUPNOK is offline
Post a video
Old 05-15-2017, 10:39 AM
Mini_Garage
will do when i get home
Old 05-16-2017, 06:11 PM
sarom058's Avatar
sarom058
sarom058 is offline
Location: Portland, OR *currently in a temporary email address
Originally Posted by Mini_Garage
-Knocking
-Squeaking
-Hard Start
Those don't sound like related symptoms. How long have you had your Mini for? Are there any other repairs that you've ever performed/know have been performed in the vehicle's history (ie timing chain tensioner, oil pressure sender, supercharger oil service)? With these cars at 150k, it's easier to start with what you haven't done than what you have, lol.
Also, how overfilled is your oil?!? These cars take a maximum of 5 quarts. If by some stroke of accident you have more than 5qts in there, I really recommend you get down there immediately and drain a bit. It's always better to underfill an engine with oil than it is to overfill it.
Old 06-28-2017, 12:00 PM
Mini_Garage
Link to my youtube which shows my problem...did new balancer, new timing chain guides/tensionier/chain, new oil.
Old 06-28-2017, 12:08 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Moving you the Stock Problems/Issues section.
Can definitely hear an odd noise on the video. Is it throwing any codes? I am thinking either a chain or the supercharger.
Old 06-28-2017, 12:12 PM
Mini_Garage
no codes, it threw low oil and vacuum leak but i fixed those issues. also car goes into boost and such. guide from the oil pump on the timing cover it slightly cracked but talked to detroit tuned in clawson mi and the owner told me it should be fine to reuse. i have a feeling its the cover though cause sounds like a chain slapping to me.
Old 06-28-2017, 01:03 PM
Whine not Walnuts
Taking the valve cover off is not that bad and with a good light should be able to see if the chain is loose. At your mileage might want to put a new gasket on and they only cost $20-$30. But that sound was intermittent, at least to my not to good ears, and I would think the chain would be a constant sound.
By chance did you see the thread about the guy finding a piece of the rocker arm had broken off?
https://www.northamericanmotoring.co...ease-help.html
Old 06-28-2017, 01:05 PM
Mini_Garage
took off my valve cover and did my gasket. also everything in the head looks amazing. also i did a timing chain kit.
Old 06-28-2017, 01:30 PM
Whine not Walnuts
I'm back to the supercharger, or, something is moving into the fan when the engine torques.
Old 06-28-2017, 01:37 PM
Mini_Garage
i havent seen anything abnormal with the fans. may be the throwout bearing or possibly something in the trans... needs a new pressure plate but idk
Old 06-28-2017, 01:50 PM
Whine not Walnuts
By chance did you have the SC intake duct opened up?
Old 06-28-2017, 01:57 PM
Mini_Garage
no intercooler was on and intake boot was fine
Old 06-28-2017, 07:42 PM
Whine not Walnuts
Hopefully one of the vendors will get this post. I know that Way Motors has a repair shop in addition to selling parts. ECS and Pelican come to mind as well.
Old 06-29-2017, 06:48 AM
Mini_Garage
i just hope someone can help...its been like 7 months
Old 06-29-2017, 08:00 AM
AoxoMoxoA's Avatar
AoxoMoxoA
AoxoMoxoA is offline
...guide from the oil pump on the timing cover it slightly cracked but talked to detroit tuned in clawson mi and the owner told me it should be fine to reuse. i have a feeling its the cover though cause sounds like a chain slapping to me...
Timing cover bottom guide cracked?
Yeah, I'd agree that you have an issue if something is slapping around in there hard enough to crack the inside cover...
We're talking about the portion highlighted in yellow in this pic, correct?
Might be time to investigate there again. No metal objects sitting in the bottom of your oil pan?
Old 06-29-2017, 08:23 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Interesting noise. Can you have a friend rev it up at idle while you poke around in the engine bay? Maybe with a Mechanic's Stethoscope so you can try to pinpoint where it's actually coming from. Yes, how is your oil level and do you see any metal specks in it? If you know there is something that is not in top shape that may relate to the issue, it might be a good idea to replace it. Your CEL may not be one, but did you definitely plugged into your OBDII and check for faults in the system?
888.280.7799 | 6am - 5pm PST
Old 06-29-2017, 08:28 AM
Mini_Garage
yeah i have a bluetooth scan tool that allows me to read DTCs. also there was until i cleaned the oil pan and motor out when i was doing the timing kit
Old 06-30-2017, 09:42 AM
Mini_Garage
ive been searching and seems like it could possible be the super charger going bad?
im going to use a screw driver when i get home in about 5 hours. ill post an update later. also going to take off the valve cover to see if timing was jumped from me not cracking the timing tensioner when i put it all back together.
Old 06-30-2017, 10:03 AM
AoxoMoxoA's Avatar
AoxoMoxoA
...also going to take off the valve cover to see if timing was jumped from me not cracking the timing tensioner when i put it all back together.
I don't understand this practice of installing the tensioner in a retracted state, then cracking it so it pops open...
I pre-popped mine prior to installing, and it went in easily...
Old 06-30-2017, 10:04 AM
Mini_Garage
i think i found the problem, sounds like bad dual mass flywheel
Old 07-06-2017, 05:51 AM
Mini_Garage
well redid my whole timing system and the sound still persists...maybe its my oil pump guide that is slightly cracked but i honestly dont know. its getting sent into detroit tuned to be looked over by the one and only chad miller! after i find the cause i shall let you guys know! thanks for all the help
Old 07-26-2017, 10:09 AM
Mini_Garage
bad rod bearing for cylinder 2...
Old 07-27-2017, 07:59 AM
Aspen's Avatar
Aspen
Aspen is offline
Boo. Well at least you know what the noise was.
Old 07-27-2017, 09:13 AM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
look at that slop
No offense intended. If you can see the slop in a video that is pretty bad. It is consistent with the low oil pressure in your first post. I hate to see what the bearing and may be the con rod look like. But hay, the car has 150k.
