06 GP Hood won't close / latch on driver side
The hood on my 06 GP with 82,200 won't latch properly on the driver side. This has been going on for a long time but I never bothered with it but now it's bugging me.
I tried adjusting the 10mm bolts for the hinge in every combination possible. Then I tried pushing the hook itself to see if I could tell a difference between the passenger and driver side. Seems like the driver side's a lot easier to push and I noticed the inner piece of metal on the hinge did not move together with the thicker piece compared to the passenger side. Going to order a replacement. Cheapest I found was $48.xx with $10 shipping from turnermotorsport.com and is genuine MINI. https://www.turnermotorsport.com/p-2...uine-bmw-part/ Here's a video of my issue: https://www.youtube.com/watch?v=B3tF...ature=youtu.be Anyone else have this problem? |
Bump?
Well then thanks for all the responses. :D
Replaced the bowden cables just now and everything works perfectly. Replacing the latch did nothing. The driver side cable must have been stretched. Oiled up the cables as well. |
It looks like the cable on the left side is too tight. If you compare the 2 the right side sticks out further than the left. Did you try to manually lock that side with the hood open to see if it locks at all?. I usually use a screwdriver or similar to test lathes.
There are separate cables for each side. I can see two cables connected to the pull inside the passenger compartment. As I said when I replaced the Bowden cables the hood latches properly now.
Glad to hear you got it sorted. And sorry I overlooked your bowden cable post I didn't want to see you hanging.
Thanks appreciate the effort.
| All times are GMT -7. The time now is 10:31 AM. |
