Ballast, bulb, or assembly
Old 10-22-2017, 11:48 AM
Newby05mcs's Avatar
Newby05mcs
Newby05mcs is offline
Hello everyone
my wifes checkmate with factory HID/projectors stopped working. what needs to be replaced?
i noticed yesterday that the light was a bright pink/purple. Later on, it started flickering; now its out.
Old 10-22-2017, 04:48 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Moving you to the Stock Problems/Issues area.
Newby05mcs (10-24-2017)
Old 10-23-2017, 03:53 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
Received 1,706 Likes on 1,375 Posts
If the lights were pink-purple, chances are good the bulbs finally wore out.
Old 10-24-2017, 10:44 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Yep, I'd say your bulbs are done. What's your MINI info? year, etc? I can get you the right bulbs for replacement.
Should have a DIY here: http://www.pelicanparts.com/techarti..._and_Bulbs.htm
888.280.7799 | 6am - 5pm PST
Old 10-24-2017, 02:18 PM
Newby05mcs's Avatar
Newby05mcs
thank you all, and pelican. i have read many of your articles while modding our cars.
i had swapped over a bulb from my 05 to my wifes 06 mcs checkmate, and it still doesnt work.
i put my bulb back in my car, and it works, so what do we think it could be??
i did take the bad bulb from my wifes, put it in mine, and sure enough it is burnt. in addition to a bulb, i think something else is bad.
i did notice that the small wires that connect to the pack on the back of the bulb were exposed. i put some electrical tape on them now, put possibly maybe a fuse is also out?
what do you think
Old 10-26-2017, 11:21 PM
Newby05mcs's Avatar
Newby05mcs
so heres some trouble shooting. I swapped wifes ballast amd igniter to my mini, and everything works on mine.
i moved my working ballast, igniter, and bulb over to hers, and nothing works. what would the next thing be to check?
​​​​​​​thanks in advance!
Old 10-27-2017, 03:02 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
If your bulbs work with her ballasts, then your ballasts are toast. If it were me, I’d get new ballasts and bulbs and be done.
Newby05mcs (10-27-2017)
Old 10-27-2017, 07:52 AM
Newby05mcs's Avatar
Newby05mcs
i appreciate it. basically, i took my good/working bulb and ballast out of my mini, put it in hers, and it doesn't work. I then took her ballast and tested it on my vehicle, and it works, so it looks like all the ballasts work on my vehicle.
for all intents and purposes, her car has a working bulb and ballast, and it still wont turn on (driver side). what would be next to check, considering the fact that the bulb and ballast do work.
thank you all for your consideration
Old 10-27-2017, 07:53 AM
Newby05mcs's Avatar
Newby05mcs
sorry for the confusion, to be clear, MY minis lights/ballast work fine, but when i put my lights and ballast in hers, it doesn't work.
Old 10-27-2017, 07:56 AM
njaremka's Avatar
njaremka
njaremka is offline
Alliance Member
I had to go back and re-read the thread, since I'm getting confused
Her car sounds like it has a wiring issue somewhere. Need a good multimeter to start checking the harness connections.
This is a good resource for HID related issues, too:
www.HIDPlanet.com
Old 10-27-2017, 08:34 AM
Newby05mcs's Avatar
Newby05mcs
I will try that tonight....is there any chance that there is a headlight fuse for JUST the driver side, or no?
I'll update the post with the results later on =)
