2003 S 42 pin connector by footwell
I have searched and searched I see people have the same problems but I cannot find the solution for this.. my pin connector has been heavily damaged and corroded with broken wires. is there any diagram someone can help me with to fix this? I lost my tach and speedo and abs and parking brake went on I rewired everything to the best of my knowledge and its back on.. but I want to make sure I did the right thing..
PLEASE HELP
PLEASE HELP
I downloaded the electrical manual from this site somewhere so search for that. It should have a pinout of the BCM (Body Control Module) which I guess is what you are looking for
http://wtxmc.org/MiniCooperDocs/WIRING.pdf
yea that Is the first thing I looked at the color of the wires don't match to the schematic..
this is what I have on my plug on one side from a crappy picture
22 red/ yellow dash / w/line
23 grey /white line
24 yellow w/brown line
25 purple w/ green line
26 yellow w/ black line ?
27 white w/red line
28 blue w/yellow line
29 brown w/white dots
30. yellow w/ black line
31 blue w/yellow dots / line
32 blue w/ black line ?
33 blue w/ brown line
34 white w/black line
35 white w/ ?
36 purple w/ black line
37 blue or green idk
38 dead---
39 grey w/ red line
40 black w/ white dots
41 brown
42 maybe brownish with a line
23 grey /white line
27 white w/red line
35 white w/ ?
38 dead---
39 grey w/ red line
41 brown
you can butt-plug them all together, the wires going in match the wires going out this is a common problem due to the sunroof drains clogging
a better solution is go to a junkyard and cut out the connector and soldier in the new connector ends properly.
both get the job done. Watch out there are some wires that are the same color codes but have a bigger or smaller diameter, you have to match not just the colors but also the diameter of the wire. Off top of my head there's 2 pairs of brown + purple wires, but the diameter is bigger on one set.
Jalarebel (08-06-2023)
yea I got that with the diameter of some and the color matching... but I want to make sure I'm doing the right thing the car runs and I drove it like 200 miles already.. but I have three wires idk where they go. dash works lights work all my controls the abs light is off and other things... but now I'm getting a code low thermostat temp.. I'm wondering if there is a wire in there I messed up?
