Major work going on. Anything I should check while it's torn down?
Winter has arrived so the MINI finally got parked and I'm now doing a huge list of repairs/mods.
Thermostat Oil Change Transmission Fluid Change Intake Valve clean Valve cover gasket Modify AEM for PCV block off Oil catch can installation Upgraded clamps on charge pipes Brake Ducts Change Rear Sway bar setting Rear wheel bearing Rotate tires Upgrade fog lights Upgrade DRL Downpipe Build secondary cat delete pipe Modify inlet of exhaust resonator Mount exhaust correctly If all above gets done and car runs good, up the AP tune to Stage 4 I just ordered the tool so I can check the timing chain, but I was told that was done already when I bought it. It had 37k on it then. While I've got the valve cover off, is there a way I can tell if it's the new upgraded valve cover? Is there a way to clean the PCV system inside it without damaging it? The dealer told me they did this once, but didn't say how. Anything else I should dive into while it's apart? |
| All times are GMT -7. The time now is 12:01 PM. |
