R56 Engine Oil Pump replacement
1 Attachment(s)
I need to replace the oil pump in my 2008 R56 Mini Cooper.
Does anyone have a DIY for it or has done it before? It seems like physically taking it off involves only 3 bolts but I am concerned about how to handle the chain going up to the engine. I searched for DIY's but every thread talking about it then goes to someone saying that the oil pump is not the issue and something else needs to be done. In my case the oil pump definitely needs to be replaced, as part of it is physically broken off. See attached picture. The piece in the red circle has broken off. The bolt itself is still connected to the top, but seems like it is completely separated from the oil pump at this point. The engine noise is louder than usual, I figure that the pump is vibrating and potentially causing some slack in the chain. Thanks everybody! |
When I rebuilt my '07 MCS last year, the oil pump wasn't replaced, but just removed, cleaned, and re-installed. There should be no issues with the oil pump drive chain --- it isn't "timed" to anything like the main drive chain.
Hope you can find all the loose pieces before re-assembly --- |
Originally Posted by oldbrokenwind
(Post 4159992)
Hope you can find all the loose pieces before re-assembly --- I found the parts already, they were all in the oil pan |
Originally Posted by miniauto
(Post 4160073)
That sounds great! Do you remember how it is taken off from the chain?
I found the parts already, they were all in the oil pan If you don't already have the Bentley manual, you should consider getting one --- torque specs, tightening sequence, etc. An invaluable tool when doing your own work. |
Take the center bolt out of the oil pump gear. Manipulate it off or loose. Remove the 3 bolts.
Down it comes. No need to take the crankshaft balancer bolt loose. It'll come down. First, drop the down pipe to make it easier or there's one oil pan bolt that will cross thread. Then the oil pan. Extremely thin coat of black silicone when it goes back up. Gently snug the bolts. |
The Bentley Manual here goes over the oil pmp removing and installing for your MC on page 119-13. If you plan to work on your MINI it's a good investment. You might be able to have someone send you some screen shots of it for this job as well. It'll give you tightening torque specs and more. Oil pump and parts here if needed.
Ok, that does not sound nearly as complicated as I imagined!
I will see if I can post a DIY when doing the replacement. Waiting for parts now. |
oil pump sprocket bolt removal
which tool is required? I've tried different size torx, etorx, hex, and splined bits. nothing fits. is it a specialty tool??? any help would be appreciated!
Torx 45
Originally Posted by wascobi
(Post 4477943)
Counter-hold the main crankshaft 18mm bolt (get someone to do it) while you break loose the sproket bolt! Then you can remove the whole oil pump assembly by undoing the 3 bolts (same socket size as the sprocket bolt you just removed) by using a breaker bar (they are pretty tight) (get someone to “catch” the oil pump because is heavy and it can fall before unscrewing the three bolts holding it) Good luck https://cimg7.ibsrv.net/gimg/www.nor...f1285136d.jpeg |
End of story?
(Post 4159951)
Does anyone have a DIY for it or has done it before? It seems like physically taking it off involves only 3 bolts but I am concerned about how to handle the chain going up to the engine. I searched for DIY's but every thread talking about it then goes to someone saying that the oil pump is not the issue and something else needs to be done. In my case the oil pump definitely needs to be replaced, as part of it is physically broken off. See attached picture. The piece in the red circle has broken off. The bolt itself is still connected to the top, but seems like it is completely separated from the oil pump at this point. The engine noise is louder than usual, I figure that the pump is vibrating and potentially causing some slack in the chain. Thanks everybody! today i removed the oil pan in order to look for debris in the oil pump pickup mesh, and as excepted i found metal and plastic shavings stuck right there, but guess what!!! I found my oil pump assembly broke at exactly the area you circled above! Did you get the whole pump replaced? Tomorrow i’ll take it to a welding shop to see if they can fix it! also found slack on the chain driving the oil pump, do you know, how much slack is normal? Thanks in advance |
Originally Posted by PelicanParts.com
(Post 4160292)
Originally Posted by rosslink
(Post 4560177)
Need oil pump sprocket bolt torque specs, would buy Bentley manual but selling Mini due to needing funds, so can anyone help with torque specs?
Specs good for N12, N14, N16, N18 Stage 1 = 5Nm (44 in-lbs) Stage 2 = additional 90 deg |
