Control arm bushing tool
Has anyone used this tool to put the bushings on the lower control arms
http://i.ebayimg.com/00/s/NTAwWDc2MA...TxFbY/$_58.JPG |
Yes but if you have a room a dead blow hammer and some lube is easier and faster
Save your money you don't need it. You can use a pry bar to get the stock ones off. But if your installing powerflex bushings they will slide right on without any tools.
Working as a tech for a mini dealer and replacing these on a weekly basis. I can agree with Way. The race bushings that I put on my own car was the best thing I have done. Easy to put on and easy to remove later for re-greasing when needed
How often do they need to be greased? Does it require dissassembly and do you need to do an alignment after every time you grease?
