Fuel System Monitor Bank 1 fail
Old Feb 7, 2015 | 09:49 AM
Garconis's Avatar
Garconis
Check engine light came on a couple weeks ago. Bought an OBDII scanner to check it out, since it did cause very slight power loss during moderate acceleration.
Code was P129E - Manifold Absolute Pressure Minimum Pressure Implausible
I ended up clearing the code and it hasn't come back. Chalked it up to cold weather. Anyways...
I ran a Test with the OBD Torque app and have 2 failed tests:
Min: 1,033.7. Max: 12.7.
Current: 2,073.6
Manufacturer defined MID
Min: 8,273. Max: 1.
Current: 31,984
Beside those two failed tests, the engine does make a rattling/vibration noise (almost sounds like a diesel), when driving around 2K rpm when it's cold (only happens about 25% of the time). Doesn't have the chatter at idle that is normally associated with the timing chain.
Also there is a slightly higher pitched vibration noise when cruising between 3k and 4k rpm. Even when not cold. Can't tell if it's from the engine itself or the engine bay somewhere. Hopefully it's more of just a vibration rather than an engine issue.
Anyone have insight on any of this? Mostly the Fuel System Monitor Bank 1 failed test?
2009 Mini Cooper S with 60K.
Dealer is 2 hours away...
Old Aug 11, 2015 | 09:01 AM
Mini-CS's Avatar
Mini-CS
Hey Garconis,
I just picked up a used MCS 2008 R56 85k miles.
I was researching the same failure codes and your codes are almost identical to mine. I haven't had a check engine light but my Torque OBD11 app shows the same failures in the fuel system.
Here are mine:
Min: 1,033.7. Max: 4.7.
Current: 2,073.6
Min: 8,273. Max: 1.
Current: 31,984
Did you ever find out what this issue is? I'm loving the car but a little nervous after finding these failures.
Hoping it's nothing to worry about.
Cheers
Old Aug 11, 2015 | 05:19 PM
Garconis's Avatar
Garconis
Dealer said those were nothing to really worry about, as it's really wrong with the car -- since there is only so much the OBDII can check compared to the actual MINI diagnostics too. Or something like that.
The noise I was having was the timing chain destroying itself just like last time. I'm beginning to not care as much, as I'm looking to sell the car. Every time I get one major thing fixed, another one creeps up a few months later.
Old Aug 11, 2015 | 05:30 PM
Mini-CS's Avatar
Mini-CS
Fuel system.
Thanks for the reply and putting my mind at ease. Sorry to hear you keep having issues. I love the car but I'm a bit worried. Saying that I traded in my vw gti due to never ending check engine lights. Hopefully this will be better!
Old Aug 11, 2015 | 05:39 PM
Garconis's Avatar
Garconis
Good to know. Was thinking of getting a GTI within the next couple years.
iggi
18
Feb 9, 2026 01:00 AM
khumpert
Nov 30, 2015 11:48 AM
portedbuckle
Sep 11, 2015 07:02 AM
Aug 27, 2015 12:25 PM
