Rattle Sound in Rear
I am hearing some rattling from what seems to be the left rear of the car. People have told me it's exhaust, but I don't believe it. It's way to rhythmic to be an exhaust rattle.
Not sure why that looks so bad and why there is two posts, but okay.
does it change speed with changing speeds of the vehicle? I have a broken hanger part, sounds nothing like that
Have you looked?
Might be an exaust rattle... But could be a rear sway bar.. Can't see the vid... Won't play... |
rattle
I too am having a shaking type rattle in rear of mini. Replaced four hangers but still have a noise that is getting annoying. Have new sway bar end links and a fairly new sway bar.
Originally Posted by Saltysalt
(Post 4033970)
Originally Posted by ZippyNH
(Post 4033979)
Have you looked?
Originally Posted by bneer
(Post 4034994)
Found the Source
Took my Mini in for repair over the summer. Needs a few things, but found out the sound that was made was actually from the exhaust. There is a metal strip welded to the center pipe almost right in the middle of the car. It breaks off the metal strip and leaves a gap where it can hit each side: |_ O _|
Just needs to be welded back in place. No big deal really. |
rattle and pop and pull
Thanks for the information. My pop and rattle comes from the Megan coil overs. When the temperature drops to 50 or lower it they make popping sound rear ones only. When it warms up they get quiet.
You should look further into the cause of the rattle. Coilovers shouldn't make noise like that regardless of temperature.
Rattle and pop and pull
Well they do.
