Coolant Reservoir, Coolant Wanted Out!
Old May 23, 2014 | 09:52 PM
  #51
Systemlord's Avatar
Systemlord
Yes, not too many cap failures most of the time is the reservoir that has hairline cracks at the base, Which you would be low on coolant and see the drips near between the transmission and core support.
Glad you got it sorted.
Whenever I perform oil changes I use bungee cords with the hooks of both ends to get the reservoir out of my way and have noticed that hard plastic piece that attaches to the bottom of the base has a couple of drips only when I put strain on it. It's like a dark gray elbow.
Originally Posted by mbwicz
I don't know how well it would get rid of all of the carbon, but how about a track day? Higher combustion temperatures under load tend to clean up some buildup, plus it may be a satisfying way to recover from the last few weeks.
Have you had the intake ports/valves cleaned of carbon buildup, that can also lead to the engine running less than optimum.
Have fun,
Mike
I had the intake system walnut blasted by the dealer in October of last year, cost me $800 but made me some extra HP and TQ (5-10hp), I'm sure of it! The price has come down since it seems that it's going to be consider a normal maintenance procedure every 30K-50K on the N14's. You know maybe I need to go for a canyon run and run the engine harder than I normally do, that might remove more carbon with more heat, great idea! Most of the clean-up of carbon using BG 44K has been stop and go traffic, I bet I should see more cleanup on sustained trips.
Old May 23, 2014 | 09:57 PM
  #52
ra2fanatic's Avatar
ra2fanatic
WSB doesn't unlock extra HP, you probably are feeling the HP/TQ you lost from all the carbon build up in the first place....
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
blackie
Jan 18, 2017 09:56 PM
tylewis
Aug 18, 2015 06:53 AM
kwijmbo
Aug 5, 2015 09:00 PM
