Is it normal to get rust on the trunk door over the parking plate? Warranty???
Old Oct 1, 2011 | 09:28 AM
Fatandre's Avatar
Fatandre
I was washing the mini today and desided to do it very well. When I took the panel off and found RUST!!. Its actually quite shocking. This is a 2005 car. WtF. Is this a common thing on the MINI?
Is there any warranty? The car has been taken care off very well. Wax it every 2 weeks. What are my options here?
Old Oct 1, 2011 | 02:28 PM
ZippyNH's Avatar
ZippyNH
10 year rust perforation warrenty...must have been regularly inspected by mini to quailfy..look in the warreny book for rust...it is seperate. Very common location.
.Moisture ...little airflow....no cleaning in threa behind the plate....
Old Oct 1, 2011 | 02:53 PM
Capt_bj's Avatar
Capt_bj
10 year rust perforation warrenty {sic}
surface rust is not perforation . . . but you may have friendly dealer
Old Oct 1, 2011 | 04:57 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Areas to keep an eye on. R50/52/53.
1- Area behind rear license plate.
2- Bonnet - where the bottom part of the chrome trim for headlights meet the Bonnet.
3- Both left and right sides under the bottom of doorway's rubber trim The whole length under there where the metal sections are pressed and sandwiched together and spot welded.
4- Check body area below each tail light. Water can sit in there and if there are any paint chips moisture gets under the paint.
There are some tiny holes at the bottom of each door. Keep them free and open for water drainage.....
Weird is that I have some of the usual road rash up front for a daily winter driver with 130K miles, yet no chips have even shown a sign of rust. Seems to be just where water can sit for periods of time.
Old Nov 24, 2011 | 06:49 AM
FP's Avatar
FP
It doesn't have to be rusted through for the warranty to cover it. If the rust is comming from the inside out it should be covered. I just took mine in because the driver's side door at the bottom was starting to blister. It was rusting from the inside out. Mini replaced the whole door for me under warranty.
Old Nov 24, 2011 | 06:57 AM
Fatandre's Avatar
Fatandre
Could you give me more info?
The problem is I bought the car used and it has no history of beeing servised. Does that matter?
Old Nov 24, 2011 | 07:57 AM
FP's Avatar
FP
I bought mine used too. That should not matter as the warranty is transferable to the new owner. They will test the panel to see the paint thickness, to make sure that panel has not been repaired. If it has been repaired previously, then the warranty will not cover it.
Old Nov 24, 2011 | 10:49 AM
ZippyNH's Avatar
ZippyNH
I kinda doubt you will get coverage...
If I remember right you imported you car on your own, and you have not national dealers...
The warranty we are speaking of is provided by MINI USA...
I suspect other area's have their own corporate entity that provides warrenty service for their distribution areas...(my 5 year old wanted me to use that icon)
Old Nov 27, 2011 | 05:27 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I have rust above the trunk handle too. It took about 5 years to form, since mine is not the original trunk lid. A new trunk every 5 years is not cool so I might go with a carbon fiber one and add a ground strap for the defroster grid.
Old Nov 27, 2011 | 05:29 PM
Fatandre's Avatar
Fatandre
Can you get carbon ones?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
PrimePower
Aug 11, 2015 12:51 PM
