Electric steering wheel lock malfunctioning
1 Attachment(s)
(R56 S)
Received this pretty little picture this morning: Attachment 170668 According to the manual; Lights up in red: Electric steering wheel lock malfunctioning The engine can no longer be started. If applicable, do not switch off the engine. Contact your MINI Dealer. I've been able to restart the car three times today since this, and driving has not been affected. A Google search for "Electric steering wheel lock malfunctioning" shows several posts from Bimmer forums, of owners having to have the whole steering column replaced. And the MINI2 and NAM links do not have any updated info for us. My gut tells me I have a funky ECU, as I've had weird electric problems with this car since day one. I've had a couple reflashes from MOSA during checkups and at least one at Harrison's, and the other ghost problems disappear for awhile...but have resurfaced from time to time. For stihs and giggles, I'll disconnect the battery tomorrow and hook my charger up to it for awhile. Reconnect and hope it "resets" the ECU. If still present, I'll make an appointment with Harrison's monday morning if possible. I always drive in sport mode, and turn off ASC. I checked the power steering fluid, and it's below Max but well above Min. Ur thoughts? http://www.harrisonmotorsports.com/ |
6 Attachment(s)
Battery didn't need much charging, only ran one cycle before the charger said it was full. Battery still disconnected, will leave it sit as is until I need to go later today.
Checked fuses, all are good; Engine fuse box Attachment 170669 How can you tell if the green ones in the middle and the black ones in the upper right corner are bad? Interior fuse box Attachment 170670 Attachment 170671 Took the steering column cover off as well, hoping to see a solenoid or something obvious; Attachment 170672 Attachment 170673 Attachment 170674 |
Originally Posted by ruabadfish2
(Post 3344228)
(R56 S)
I checked the power steering fluid, and it's below Max but well above Min. Regardless, I hope you are able to get this to reset without any extra expense. I also like your mileage. Good to see someone putting miles on their Mini and not trading it.:thumbsup: |
Originally Posted by gregsmini
(Post 3344612)
I'm confused. I thought the R56 Mini's had electric power steering and did not have power steering fluid.:sly:
Haha! I tried looking for the blinker fluid too, are you guys sure it's there?
There may not be any power steering fluid, but my brake fluid level is ok! :lol: |
(Post 3344980)
This happened to me. Reset all the modules in the car (you need the tool
for this frankly you can not own this car without the tool). Fully charge the battery deep cycle charge. Disconnect battery for a few hours. With car running reset all modules again (may need to do a couple times, also, may need to restart car a couple times) Keep trying steps it should eventually reset. This is a hard one to make go away. MAKE SURE YOUR KEYFOB IS VERY MUCH CHARGED TOO |
(Post 3344228)
(R56 S)
Received this pretty little picture this morning: http://i80.photobucket.com/albums/j1...10819-0821.jpg According to the manual; Lights up in red: Electric steering wheel lock malfunctioning The engine can no longer be started. If applicable, do not switch off the engine. Contact your MINI Dealer. I've been able to restart the car three times today since this, and driving has not been affected. A Google search for "Electric steering wheel lock malfunctioning" shows several posts from Bimmer forums, of owners having to have the whole steering column replaced. And the MINI2 and NAM links do not have any updated info for us. My gut tells me I have a funky ECU, as I've had weird electric problems with this car since day one. I've had a couple reflashes from MOSA during checkups and at least one at Harrison's, and the other ghost problems disappear for awhile...but have resurfaced from time to time. For stihs and giggles, I'll disconnect the battery tomorrow and hook my charger up to it for awhile. Reconnect and hope it "resets" the ECU. If still present, I'll make an appointment with Harrison's monday morning if possible. I always drive in sport mode, and turn off ASC. I checked the power steering fluid, and it's below Max but well above Min. Ur thoughts? http://www.harrisonmotorsports.com/ |
This happened to me when I updated the CAS module to newer software stand using WinKFP. In order for this error to go away, you need to reset the CAS's error memory, but you need to have ignition switched off! It wont go away if the ignition is on, because the electric steering lock is working at the time.
What you actually need to perform this, is a D-CAN USB cable (ebay, ca. $100) and an ordinary laptop. The software you can get on the Internet and because it's BMW specific, it's much better than any generic thing. Alternatively, you need to visit the dealer and have him reset the errors the official way. How much it's gonna cost you, I don't know... |
I got the same problem with mine last friday but It was the battery, my Aeroforce Interceptor gauge is defective and it turns on and off while car is off and alarm its armed, so it discharge the battery.
It also resets the clock and the odometer so I decided to took my car back to the workshop to get the gauge removed and send it back for a software checkup for this matter. |
I guess us 2008+ owners are lucky MINI deleted the steering lock.
I am still really curious as to where this supposed "power steering fluid" in the original post was found. :impatient: |
Originally Posted by strobeyprobey
(Post 3403031)
:lol:LOL! I totally missed that while reading the thread. I was thinking it must be the brake fluid because the only other fluid to check is the engine oil and coolant.
:thumbsup::thumbsup::thumbsup:
Haven't had this checked out yet, now getting random other notifications, well, randomly. Wondering now if it is the battery. One project at a time tho, currently working on a thermostat leak. December is a horrible month to try an buy parts
I have the same issue. Interested in the end of this story...
I'm getting the same warning but my car works fine. Will take it to the dealer next week to get it checked.
Dealer said that there is a communication problem between the key and the steering wheel module, and that the entire steering wheel column needs to be replaced, which will cost around $900. >< Since my car is working fine, I think I'll just take my chances and get it fixed when there is an actual problem.
Originally Posted by johnzzx
(Post 3479435)
$900!?!? Are you serious? Holy crap! My light came on the other day (in orange though, not red), and while I freaked a little when it first happened, by turning the wheel, it went away and has been fine since.
Any updates on this, I have the same problem, been driving with it for about 3 months. Annoying since it blocks the digital speedo. I saw someone mentioned a tool to reset. Any more details on that? I did a quick look for the cable and BMW software mentioned by the other poster, but not sure exactly what to buy or if there is a reliable source for it. Also don't have a laptop. Steering works fine and no issues starting. I can also hear the lock actuating when you insert and remove the key.
Originally Posted by gregoryp
(Post 3743072)
Happened to me when I left it at dealership. Drove it back and they tried to feed me the same BS that steering column gone 900$ etc. I just told them to clear code and I wasn't paying for it. And in 2mins it was sorted
Hey guys. So did having the dealer clear the codes work? Mine has been on for a few weeks. No affect to the steering and the car starts right up everytime. Just curious what the end result was for this. Thanks
Originally Posted by carmelo123
(Post 3766920)
EDIT: Just ended up taking it in and having the indy shop take care of it.(Bullet Performance in Costa Mesa for you OC guys) $594 total parts and labor. |
