2010 MCS ISSUES- Stalling, crackling, Radio Shuttoff, hatch....
Old Jun 7, 2011 | 09:23 AM
RotaryGuy's Avatar
RotaryGuy
Ok, Im back.. And not under great circumstances..
Our 2010 Chilli Red S is not feeling Well.... Here are the issues..
1) Engine stalls when you first start the car, have to push the start button twice before it will take.. (not weather dependant, just random)
2) Occasionally there will be a crackling noise from under the hood on startup, this will occasionally cause the Radio to shut off completely.. (seems electrical) this crackling is occasionally followed by a whooosh noise..
3) Noisy rattle when air conditioning kicks on. (car was in for this issue and they claimed to repair a recall related to a bushing on the A/C lines but it still does it)
4) Rear hatch only opens with the use of the fob.. ( they calim this is common and are ordering parts..
5) Common problem- The engine is stupid noisy- like a diesel car.. But I hear this is normal?
The bad part is that they cannot get us in to look at the car for another week or more!! If the car hard starts again I am going to call Mini Roadside assistance...
Can anyone shed some light on this?
Old Jun 8, 2011 | 09:57 AM
RotaryGuy's Avatar
RotaryGuy
Earliest they could get me in is the 20th of this month.... I am considering buying a 3rd car that is daily driveable....
Old Jun 13, 2011 | 06:11 AM
RotaryGuy's Avatar
RotaryGuy
Bought a miata as a spare car.. At least now when the mini goes in we have a mode of transportation.. ha~!
Old Jun 13, 2011 | 09:06 AM
cooperjunkie's Avatar
cooperjunkie
I just had the rear hatch not open yesterday and has been rattling for weeks now. Mine is diesly loud too. And if it's hot forget about opening the roof. Oh and the hood scoop is warped all to hell. Goes in for fixes on Thursday.
Old Jul 7, 2011 | 10:17 AM
RotaryGuy's Avatar
RotaryGuy
Dropped it off this morning. Also noticed that the coolant was low on Saturday. Haven't driven it since. Really like the service guys at the dealer, i know they will get the car sorted out.
Old Jul 8, 2011 | 06:06 AM
RotaryGuy's Avatar
RotaryGuy
Here is the list of the repairs they are performing:
A/C Compressor replacement
Timing Chain replacement
Reprogram on the ECU
New electronics for the rear hatch
SHould have the car back today.
Old Jul 8, 2011 | 11:18 AM
RotaryGuy's Avatar
RotaryGuy
Picked it up a few hours ago. List was as follows:
Engine Rattle Fixed by-
GASKET RING
GUIDE RAIL
CHAIN TENSIONER
BEARING BOLT
BEARING BOLT
GASKET RING
SLIDE RAIL
TORX BOLT
TORX BOLT
HEX BOLT
SPROCKET
TIMING CHAIN
CHAIN TENSIONER
SIM 11 02 07
Timing chain was 72mm (max spec at 68mm) and the car had jumped time causeing the hard start issues. Tech noted that the tensioner bolt had not been torqued to spec and was backed out. Also programmed the car SIM to bring the car I Level to date.
Rear Hatch fixed by-
5113903 Replace
Replaced microswitch due to permanent Failure
HVAC noise fixed by
Replaced malfunctioning A/C compressor
The car is a whole new car.. I wouldn't doubt that the car came from the factory malfunctioning because it drives and sounds correct now..
Couldn't be happier. Scares my wife a little that we have had so many little things go wrong, but I feel confident that it will all be addressed during the warranty period.
Miniwaukee
Jan 13, 2023 09:05 PM
madmaxxed
Sep 2, 2015 03:32 PM
smarsha11
Aug 26, 2015 06:21 AM
Miniwaukee
Aug 24, 2015 01:52 PM
smarsha11
Aug 24, 2015 06:03 AM
