North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   2004 mcs axle nut won't come off. (https://www.northamericanmotoring.com/forums/stock-problems-issues/203571-2004-mcs-axle-nut-wont-come-off.html)
Chrisindelaware Jan 30, 2011 11:39 AM
Help!!! I'm stuck mid project. I'm replacing the left front wheel hub and bearing. I have the tire off, caliper tied up, disc off(yeah I had to drill it out). I'm looking at the hub and axle nut. I don't have air at my new house yet, so I haven't tried that yet, I can't get this axle nut off. Did I miss something in my research? Is it reverse thread? I have tapped the stake out so that it isn't in the way. I'm replacing the hardware so I'm not worried about that, just don't want to take a chisel to the axle nut with the shaft right there. What did I miss? Retorque is 134 ft lbs I think so it shouldn't be that hard to get off. I put creeping oil in it an hour ago. Still not budging. I did search the forums but didn't find this answer. Thanks.
Chrisindelaware Jan 30, 2011 12:33 PM
Ok, I have now put the entire thing back together and tried to break it free using a half inch drive and an 18 inch cheater bar. Wheels on the ground e brake on. Am I the only one having a love / hate thing when I work on my Cooper?:)
JIMINNI Jan 30, 2011 12:39 PM
:lol: Cars come into the shop here and we have to use a 4 foot pipe to get some of them off :eek: Guess some shops either dont have a torque wrench or they do but they just stay in the tool box :razz: You have tapped the dimple out correct?
Chrisindelaware Jan 30, 2011 12:50 PM
Yes, I used a punch and pushed it back. They are standard thread correct?
Some Guy Jan 30, 2011 03:45 PM
The are standard righty tighty. I used a 1/2in Ingersoll Rand to get it off. You dont have that option regrettably so you could try a bit of heat. Just make sure not to use to much or you could cook the wheel bearing.
Chrisindelaware Jan 30, 2011 04:02 PM
Cooper 3 Chris 0, it has drawn first blood. Done for the night, bringing home the big fu****g breaker bar from work tomorrow. I used mapp gas. It didn't approve. The cheater bar slipped and took a chunk from my palm.
Candu61 Jan 30, 2011 04:54 PM
Save your knuckles and pick one of these up :thumbsup:
http://www.harborfreight.com/1-2-hal...nch-45252.html
JIMINNI Jan 30, 2011 04:58 PM
Well I would stay away from that as most likely thats what caused his pain in the first place :lol: We use a .75 drive on a 2 foot breaker and add pipe accordingly :thumbsup: Impacts are a no..no on Minis :nod:
Eric_Rowland Jan 30, 2011 08:03 PM
Time to go Rambo on it. "It drew first blood!" :lol:
Good luck! (and wear gloves!)
steve20607 Jan 30, 2011 09:52 PM
For future reference, is the axle nut of a reverse or regular thread? Duhhh...never mind, the answer was stated above...
Alan Jan 31, 2011 02:32 PM
Even to get the nut undone? I won't argue with not using a impact wrench for tightening.
I have the old fashioned "hit with a hammer" impact driver that I use on stubborn stuff.
JIMINNI Jan 31, 2011 08:08 PM
Well I guess you could, but more than likely if there is a impact around it will be used to "undo" and "do" if you no what i'm saying
:wink:
Chrisindelaware Feb 1, 2011 03:54 PM
Work has kept me busy. It's in the garage with a 3/4 inch drive and 5 ft breaker bar sitting next to it. Borrowed them from a buddy that works on tractors. That bolt is coming off in the next day or two.
JIMINNI Feb 1, 2011 05:58 PM
This is cool thread kinda like a drama :lol: Give that nut heck tomorrow :thumbsup:
Chrisindelaware Feb 6, 2011 10:45 AM
I took time away from work today to try again. It was me and a 5ft breaker bar versus the nut. My kids were huddling at the door to the house, knowing this thing had made me bleed and cuss. After about 20 degrees of flex in the breaker bar the nut gave with a resounding crack. They cheered. I've never been applauded before for taking a nut off of a half shaft. When this is all said and done I'm posting a "how to" for all of the other fools taking this project on. If I ever catch a mechanic using an impact wrench on my car again I might just break his fingers.
JIMINNI Feb 6, 2011 12:44 PM
Woo Hoo! :thumbsup:
SRTech Feb 8, 2011 05:46 PM
I've got one now that was put on and spun on the threads. I backed it off with my 3/4 drive, 4ft. bar, but the threads are toast. I'm hoping to save the driveshaft by rethreading since the owner can't afford a new one. The shop that did it also cross-threaded one of the wheel bolts and it broke while removing it. Good thing I was replacing the hub/bearing anyway.:nod:
Steve
