rear knocking sound video: any guesses?
Whenever I drive slowly around 20 mph over uneven roads and bumps, I hear this knocking sound from the rear of the car. It also happens when I swerve back and forth or rock the car by pushing as in the video. Nothing seems loose in the boot, spare tire, muffler areas, or hatch.
When I brought the car to the dealer, they diagnosed a different sound from the front due to a loose transmission bolt. Ironically, I had complained about this sound last year, and they couldn't find anything before. I plan to bring the car in again to drive it with the foreman. I'm thinking it's the rear sway bar bushing as posted by Helix13mini in another thread: SI M33 02 09 Rear Axle January 2010 Technical Service Load Graphics SUBJECT Rattling and/or Knocking Noise from the Rear Axle MODEL R55, R56, R57 without Sport Suspension SITUATION A rattling and/or knocking noise may be heard from the rear axle and/or rear suspension while driving over uneven roads. CAUSE The inner diameter of the stabilizer bar mounts may be too large for this application. PROCEDURE [GRUSB3309-02.JPG] Use a caliper gauge to determine whether the rear stabilizer bar is 16mm (1) (non-sports suspension). If the stabilizer bar is 16mm, replace the stabilizer mounts (2) with P/N 33 55 6 754 823. PARTS INFORMATION Part Number Description Quantity 33 55 6 754 823 Stabilizer mount 2 WARRANTY INFORMATION Covered under the terms of the MINI New Vehicle Limited Warranty Defect Code: 33 55 01 39 00 Labor Operation: Labor Allowance: Description: 33 55 021* Refer to KSD2 Replacing both rubber mounts for stabilizer |
