Door Key lock/unlock won't work
Hi, I purchased a 2003 Mini CVT. It is used so I am working though all the little issues. The car came with one key. It is a remote key and works fine. I can press the lock button to lock, unlock and it unlocks etc. The problem is that I can not use the key the old school way by putting it in the key hole to lock and unlock the doors from outside the car. I ordered two new general keys (no remote) to be used as backups but they don't work in the drivers side door keyhole. When I looked in the manual it says something about activation at your local Mini dealer. So I'm thinking it is an electrical mechanism that needs to be activated. Is anyone familiar with how to activate the manual lock mechanism on the driver side door so I can use the key if the remote battery goes dead. This is a great forum. :grin:Thank you in advance for any help here.
Best Regards, Wilkiewheels |
very strange, i just bought a mini on friday. one of the keys is dead and neither will open the door manually. considering it is guaranteed that i will lock the keys in the car at some point this is a bit worrying.
guess a stop at the dealership is called for tomorrow |
Originally Posted by wilkiewheels
(Post 2988479)
wilkie,
did you ever find out what the problem was? I just learned (the hard way) that mine doesn't unlock the old school way either. |
I'd recommend popping the door panel off and taking a look at the mechanism inside the door. It's not too hard to do. I think there's 2 torx screws in the armrest and the rest of the fasteners just pop off. Start prying with a nylon pry bar or a screwdriver wrapped in a cloth at the bottom of the panel and then work your way around. You might find that something isn't connected properly.
| All times are GMT -7. The time now is 11:19 AM. |
