That can't be good-CV Joint failure
After replacing both Half Shafts 1200 miles ago (split boot discovered during clutch replacement). There was a wierd torque steer upon down shift that began immediately after replacemenm:sly: , but I chalked it up to single mass flywheel...but no chatter, clicking, or growling. Upon slow sharp right hand turn up a steep side road POP! :eek2: luckily no other damage, (other than someslight scraping of wheel. Ball joint is good; don't know why it happened. Any suggestions?
https://www.northamericanmotoring.co...m/DSCN0824.JPG https://www.northamericanmotoring.co...m/DSCN0827.JPG |
I would presume some sort of part failure - by chance was it OEM or aftermarket new or rebuilt?
Looks like something bound causing the CV sleeve to fracture. A similar thing happened to me when my CV boot cracked and a largeish rock got lodged in there on my old civic.
Hey - I blew my original driver's side back in May. Replaced with a "DSS" from fcpgroton (read: cheap chinese trash w/ lifetime warranty) and just broke my second of those. If you went with one of the cheapo new or remanu'd ones, I can commiserate.
Driveshaftshop.com does not list any mini applications, however I just called and they do indeed have the plans for R53 axles, "stage 2" which have 1yr warranties and are rated up to 450hp. $399 for the driver's side, it'll take them a few days to build it in-house and a few days to ship. So we'll see, but I wish I had called them back in May. |
Originally Posted by Ironraven
(Post 2890438)
Cheap Chinese steel FTL.
what milage are you guys replacing the shafts?
It was a "new" Car-Quest First Equipment something...the blueing is actually heat treatment, I replaced the half-shafrts at 65K only because I was replacing the clutch and I had a torn boot...and a BIL in the business so I get my parts at cost. (hehe, I d ont't think you can put a cost on this cv...)the new shaft had 1200 miles on it and 500 of those miles were clutch break-in. I just got back from pressing carrier bearing into housing.
I got the same thing from fcpgroton, and blew out a cv joint in that same way just 3 weeks later.
POP goes the Driver CV Joint
I should have gone OEM....Just broke the other CV, normal driving about 1000 miles since right side broke...Stay away from aftermarket half shafts.
| All times are GMT -7. The time now is 11:03 AM. |
